968 Turbo race car
Porsche 968 Turbo Race Car
3.1 L Turbo
> 400 whp
2200 lbs
(will start thread now and complete after track weekend)
Man - that's a monster and I'm not talking about the spider in the background! Can't wait to hear more!
<!--quoteo(post=78758:date=Aug 26 2009, 12:30 PM:name=Radiologue)-->QUOTE (Radiologue @ Aug 26 2009, 12:30 PM) <{POST_SNAPBACK}><!--quotec-->Porsche 968 Turbo Race Car
3.1 L Turbo
> 400 whp
2200 lbs
(will start thread now and complete after track weekend)<!--QuoteEnd--><!--QuoteEEnd-->
And on the hallowed ground at Barber, too.....you are "the man!"
Looks like a real beast!
Was this the car advertised by Ruf in Texas?
<!--quoteo(post=78909:date=Aug 27 2009, 12:15 PM:name=Eric_K)-->QUOTE (Eric_K @ Aug 27 2009, 12:15 PM) <{POST_SNAPBACK}><!--quotec-->Looks like a real beast!
Was this the car advertised by Ruf in Texas?<!--QuoteEnd--><!--QuoteEEnd-->
Yes, this car was evidently built by one of the guys associated with Ruf. I'm not sure of the entire history, but reportedly over 200k was spent building this car.
My mechanic and friend (Dave @ Smith Motorworks) has spent the last year sorting out overheating issues, and he has finally resolved any and all overheating problems. The engine ran like a dream this past weekend at Road Atlanta-------Yaaahoooooooo!
I bought the car from a guy in Wisconsin shortly after he had bought it from the guy at Ruf. Many not so good things happened at multiple track events thereafter. First of all we found out that somebody had concealed a head gasket leak by putting ceramic material in the cooling system. The custom radiator was clogged with this glass like material. We tried running the car after flushing the radiator but to no no avail. The radiator was not flowing. We had the same custom radiator re-made. The car ran cooler but the temps just kept getting higher and higher the longer I stayed out on the track. I always tended to ignore the temps because the car is so amazing to drive, so I definitely contributed to blowing a few head gaskets. Dave spent some time researching and ultimately came to the conclusion the the cooling system was totally designed incorrectly. The radiator was too big to fit under the hood in a vertical orientation. Whoever designed the car had fabricated obliquely oriented mounts to hang the radiator in an angled manner. A huge intercooler was placed in front of the radiator. The orientation resulted in very little air flow through the radiator. Dave ripped out the radiator and replaced it with a new custom dual pass radiator that is close to stock size and vertically mounted directly behind the intercooler with little or no gap. New custom fans were installed. Now she is cool as can be. The 968 never got over 200 F on 15 lbs of boost this past weekend.
Hey Eric
Have I seen a video of you at Road Atlanta during a NASA event?
OK, Here is the build as she now sits...
<b>Motor, Turbo, Driveline & Engine Cooling / Exhaust</b>•
  • </li>
3.2 Liter Sleeved Block
• Balanced and Blueprinted
• Corky Bell built Turbo using Garrett hybrid T-60. Front mount intercooler and mandrel bend turbo piping
• Tial external waste gate
• Tial blow off valves
• Crank - knife edged and cross drilled
• JE 106.5mm pistons
• Pauter machine Billet steel rods
• Balance Shaft Delete
• Pauter dry sump oil pump system
• 15 qt capacity oil reservoir
• Moroso aluminum oil filter housing with reuseable filter element
• Custom fab aluminum oil cooler
• Extrude honed 944 Turbo intake modded for large throttle body
• 85mm Ford Motorsport Throttle Body Part #BBK-1501
• Porsche 944 2.7 liter head; extensive port and pollish with large valves
• Head has been tapped with vent tube in rear
• Custom ground Webb cam Grind #274 (hyd)
• Porsche hydraulic lifters
• Accusump 2/ electric activation module
• Aluminum transmission catch can with filter
• Urethane motor mounts
• Porsche 968 axles with gkn Motorsports CV joints
• Porsche 968 six speed transmission with Porsche Motorsport l/slip
• Kolkeln short shifter
• Fidanza aluminum flywheel
• Spec racing stage 4 clutch
• Deist shifter boot cover w/ custom fab aluminum housing plate
• Custom dual pass all aluminium radiator made for by Griffin Racing and further modified by Smith Motorworks
• Custom 968 water pump
• Dual custom electric fans 3000 cfm
• Side exit exhaust. Header and down pipe are ceramic coated. Entire exhaust is covered by aluminum shroud
• ___HP / ___lbs of torque are rear wheels with __psi boost. (We haven't seen what this engine can really do yet)
Fuel system
• Aeromotive fuel pressure regulator
• Custom Extrudabody fuel rail
• Aeromotive Tsunami fuel pump PT#AEI11101
• Aeromotive inline fuel filter PT#AEI-12301
• Steel braided fuel and oil lines
• 96 lb injectors
• Fuel safe roll over protection vent tube
• Custom 35 gallon fuel cell from Fuel Safe
Brakes, Suspension & Wheels
• 996 Turbo brake rotors and calipers front and rear
• JRZ 3-way adjustable coil overs front & back w/ remote reservoir
• Custom built tubular A-arms
• Tilton master cylinder and brake pedal assembly
• Tilton clutch cylinder and clutch pedal assembly
• Carbon fiber cooling ducts mounted to calipers
• Adjustable caster / camber plates
• Stainless lines front and rear
• Kinesis center lock wheels
Body & Chassis
• Nascar style chromemoly rollcage, rear half tube chassis
• One off molded fiberglass Porsche 968 body
• JLS 4 corner air jack system with roof mounted air lance adapter
• Carbon fiber 968 dash
• OEM Porsche Aero Mirrors
• Custom Aluminum diffuser
• Carbon rear wing with custom fab mounts
• Lexan rear window
• Fire retardent padding mounted in driver's floor
• Front wiper was built from a 944 Turbo rear wiper set up
• Porsche 968 tail lights
• Front and Rear custom tow hooks
• Halon Fire system in drivers area and engine compartment
• Fabricated aluminum wheel tubs, interior work, and rear firewall
• Longacre rear-view mirror
• Momo Apache steering wheel w/ quick release
• Custom fabricated steering column
• 5 point harness
• Bride racing seat
• Helmet and suit cooler
Gauges & Electronics
• 3 - Autometer 2 5/8" gauge mounting cups
• 3 - Autometer 2 5/8" gauge angle rings for dash gauges
• Autometer 2 5/8" liquid filled gauges for - Oil Pressure, Oil Temperature, Water Temperature x2, Blower Pressure, Fuel Pressure, and Transmission Temperature
• Autometer 4" Pro Comp Monster Tach with shift light
• 2 Painless wiring, 4 switch control boxes
• 2 Master kill switches
• Simple Digital System E3-F fuel and ignition system management with direct fire coils
• MSD plug wires
• Custom made crank trigger and brackets
• Moroso battery box and Optima battery
• Bosch relays
• Porsche Boxster brake light switch
• Custom mounted Painless wiring start, ignition, and fuel pump switches
• Hobbs Hour Meter
• Aluminum anodized radio mount box
• Roof mounted antenna
• Traqmate Complete and Chase Cam setup
I cannot remember which engine management system is used currently, but MoTeC is already on hand to install and tune.
Plans for future include sorting out brakes, cabin cooling (it is hot as balls inside the car which may in part be due to the exhaust piping running through the inside passenger compartment). Now I just need more time and money.
a few pics
Older pic----I'm sure this car has a history, but I'm not sure if it was ever entirely sorted out.
I gotta wipe the drool off of the keyboard! SERIOUSLY nice race car
awesome awesome car. two thumbs up.
Thats an impressive list of mods. Great car.
lol- i want the pretty blue one in the back of the first shot of post #8
tell us more about how the 3.2 is working out
<!--quoteo(post=79454:date=Sep 3 2009, 09:38 AM:name=flash)-->QUOTE (flash @ Sep 3 2009, 09:38 AM) <{POST_SNAPBACK}><!--quotec-->lol- i want the pretty blue one in the back of the first shot of post #8
tell us more about how the 3.2 is working out<!--QuoteEnd--><!--QuoteEEnd-->
Simply put, it is awesome!!! Engine feels like it has good torque even before the turbo hits. I hope to post some dyno runs in the not too distant future with the new MoTeC engine management system.
Way cool car! Must be a hoot to drive!
<!--quoteo(post=79454:date=Sep 3 2009, 10:38 AM:name=flash)-->QUOTE (flash @ Sep 3 2009, 10:38 AM) <{POST_SNAPBACK}><!--quotec-->lol- i want the pretty blue one in the back of the first shot of post #8<!--QuoteEnd--><!--QuoteEEnd-->
Flash - I didn't know you were into older BMW 5ers!!! [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
<!--quoteo(post=79438:date=Sep 2 2009, 10:37 PM:name=Radiologue)-->QUOTE (Radiologue @ Sep 2 2009, 10:37 PM) <{POST_SNAPBACK}><!--quotec-->Have I seen a video of you at Road Atlanta during a NASA event?<!--QuoteEnd--><!--QuoteEEnd-->
Wasn't me, I'm on the other coast. I do have a bunch of vids on youtube though.
It looks like the car has been taken to the max in every way possible. Nice!
Is your fuel cell the Kokeln design (built by Fuelsafe) or custom? Any pics of the underside of it? I need more capacity for enduros.
<!--quoteo(post=79454:date=Sep 3 2009, 09:38 AM:name=flash)-->QUOTE (flash @ Sep 3 2009, 09:38 AM) <{POST_SNAPBACK}><!--quotec-->lol- i want the pretty blue one in the back of the first shot of post #8<!--QuoteEnd--><!--QuoteEEnd-->
I was going to start a thread a couple of weeks ago called "Ran into a nest of Cobras", but was too embarrassed because I forgot to take pictures, even though I had my cell phone with me. I know this is off topic, so I'll keep it brief, but a couple of Saturdays ago, I pulled into a classic Jaguar shop's parking lot, primarily just as a more-interesting-than-average place to do a U-turn, and what should be going on but a private dyno day for the local Cobra club! What a collected of gorgeous, phenomenal cars! Talk about drool-inducing!
lol - yeah - i had a bad day the other day when i was at radio shack and in the parking lot were a 360 and a cobra - i didn't know which way to look
looking forward to hearing more about the 3.2 work - been really thinking about that
What a beauty! Nice to hear you where able to finally get the cooling issues under control. Keep us posted!
<!--quoteo(post=79461:date=Sep 3 2009, 11:07 AM:name=Eric_K)-->QUOTE (Eric_K @ Sep 3 2009, 11:07 AM) <{POST_SNAPBACK}><!--quotec-->Wasn't me, I'm on the other coast. I do have a bunch of vids on youtube though.
Is your fuel cell the Kokeln design (built by Fuelsafe) or custom? Any pics of the underside of it? I need more capacity for enduros.<!--QuoteEnd--><!--QuoteEEnd-->
As far as I can tell everything on this car is custom.
Last Post by White968
06-16-2011, 02:13 AM
Last Post by Julian Allen
11-28-2009, 09:04 PM
Last Post by Lonestar968
10-06-2008, 04:00 PM
Last Post by spin
09-24-2008, 12:53 PM
Last Post by DayDreamer
08-20-2008, 03:28 PM
