Threads: 63
[quote name='Cloud9...68' post='49009' date='Mar 11 2008, 06:14 AM']Scott,
Thanks for the info - your post was VERY helpful. My car isn't a daily driver, so I won't be under any time pressure to have the car running to get me to work on Monday. A few follow-up questions:
- Jason at Paragon feels strongly that I should replace the races while I do the balance shaft seals. I'm embarassed to ask, but what exactly are these? They sound like parts of some bearings, but if so, I don't see how they could contribute to leaks. Did you replace your races? If so, how hard was it to do?
- Other than the flywheel lock, and picks and such, did you you any other "special" tools on any part of the job?
- Finally (I hope), did you replace the oil pump sleeve along with the crank seal? And how hard is it to get the crank seal out? Again, I'm concerned that if it's really difficuly to pry out, I may damage something (e.g. gouging the shaft the the seal goes around) when I don't currently have a problem.
Thanks again![/quote]
Glad this helps. PM Sent -Scott
SOLD! 1992 - 968
Threads: 51
Cloud...yes I bought the races as well. The arnnworx DIY has a mention of the races and it does not look too hard to put in. (as in no press needed) We will see. I am waiting on my pin wrench so I can get at it again.
I am going to guess on my belt tension and have a shop set it.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 11
IMHO arnnworx.com has been just as useful as clarksgarage.com in making me able to fully self-maintain my car (I've never taken a Porsche to a mechanic for repairs!). His sight has way more than just tools for sale. Great write-ups, and fantastic tips and tricks all over. His notes on resealing a power steering rack saved me from doing it wrong.
Some of the best tools are intangible. I got all my special tools (belts and rear bearing) from Bruce - top notch service and quality. But I'm sure you could buy the same set from any source and it would work very well too.
Arash - '95 968 - '93 968
and the best one: '84 944!
Threads: 51
Cloud, you will need the pin wrench to remove the gear/pully off the lower balance shaft. It keeps the pully from turning while allowing a socket onto the center nut.
I did not order or need the thin 27mm open end wrench. I have everything off except the lower b/s pully and the back guard.
I have to get those 2 frozen hex-heads off first to free the guard.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 51
Cloud,
I did the same google and bought the tool from Harbor Freight. It won't work. The tool needs very long pins in order to work. I ordered the arnnworxs tool. In the Haynes manual they are using some adjustable pin wrench, so they must be out there, but I don't think Sears has one.
I am thinking the thin wrench might be for 944 use. I just used my open end wrenches and/or sockets on the rest of the stuff.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
