<!--quoteo(post=66774:date=Feb 9 2009, 04:33 PM:name=skiemt)-->QUOTE (skiemt @ Feb 9 2009, 04:33 PM)
<{POST_SNAPBACK}><!--quotec-->OK,
I know that there are many guys willing to lend tools at events. The guys in my local PCA club are always willing to not only lend tools but hands and knowledge as well. However, being a true boy scout coupled with my ski patroller mentality, I want to be prepared. I have been to an event where the guy who was always counted on to bring something in particular didn't come. Therefore, I am still looking for a comprehensive list of what metric tools to bring to the event. I have my own list for all the other particulars and will post my current check list here so you can add to it or suggest subtracting if you see fit.
<b>TRACK LIST:</b>
Tool Box (see expanded list below)
Parts Box (see expanded list below)
Cordless 18V Drill w/Charger
Portable 12V Air Pump
Magnetic Numbers
Floor Jack
Jack Pad
Wheel Chocks
Jack Stands
Window Air Vents
Work Gloves
Disposable Rubber Gloves
Air Gauge
Flashlight – 4 Cell Maglight
Duct Tape
Contractor Blue Tape
Tie Wraps
Twist Ties
Windex
Paper Towels
Car Towels
Shop Towels
Blanket - for laying on under car
Hand Cleaner
Helmet
Driving Gloves
Driving Suit
Rain Gear
Canopy
Chairs
Table
Cooler (w/ice & drinks)
<b>Tool Box </b>(this is what it currently contains and looking to reduce)
Metric Wrenches
Combination wrench set
- 24, 22, 21, 20, 19, 18, 17(x2), 16, 15, 14, 13(x2), 12, 11, 10(x2), 9(x2), 8, 7(x2) mm
Open end - ignition set
- 11, 10, 9, 8, 7, 6, 5.5, 5, 4.5, 4 mm
Socket set 1/2 inch drive
- Ratchet, Breaker Bar, several extensions, flex joint, & spark plug socket
- 33, 27, 24, 22, 21, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9 mm sockets
Socket set 3/8 inch drive
- 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9 mm deep sockets
- 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9 mm regular sockets
Socket set 1/4 inch drive
- Ratchet, Breaker Bar, several extensions, flex joint, & screwdriver type handle
Metric Allen Wrenches
- 8, 7, 6, 5.5, 5, 4.5, 4, 3, 2.5, 2, 1.5 mm longs
- 8, 7, 6, 5.5, 5, 4.5, 4, 3, 2.5, 2, 1.5 mm shorts
Torx wrench set
Triple square set - 6, 8, 10, 12 mm
Lug Nut Socket - soft aluminum to pretect wheels
Ball Pein Hammer
Rubber mallet
Screwdrivers – various sizes - slotted & phillips
Channel Locks – straight and round jaws
Vise Grips – large and small
Pliers – large and small
Diagonals – large and small
Tin Snips – Left and right hand
C-Clip Pliers – internal and external
Mini-maglite
Torque Wrench – ½ drive, 10 to 150 ft/lbs
Torque Wrench – ¼ drive, 5 to 144 in/lbs
<b>Parts Box:</b>
Motor Oil – Mobil1 15W50
Coolant/Antifreeze
Brake Fluid – ATE Super Blue
Dexron II ATF
Liquid Wrench
Anti-Seize Thread Sealant
Spare Titanium lug nuts
Radiator Hoses - spare for each one
Heater Valve
Various size Hose Clamps
DME Relay
Bosch Super Cu-Electrode WR7DTC .80mm Spark Plugs
[img]style_emoticons/<#EMO_DIR#>/cool.gif[/img]<!--QuoteEnd--><!--QuoteEEnd-->
I don't take the car to tracks but I do have a set of tools in the car at all times for roadside repairs. While I have metric combo wrenches and socket sets in the basic tool set, I have added another set of wrenches to my on-board tool kit, <b>metric flare nut wrenches</b>. The 968 has several fuel line connectors, belt adjusters, etc..., that round too easily with an open end wrench, but have a shaft or tube preventing the use of a socket or closed end wrench. I have a set in the car and another one at home with my set of Metric flexible head GearWrenchs.
