With car no longer my daily driver, I've had time to really work from bumper to bumper over the last 4 weeks and fix anything that had broken, replace anything that was missing from either the PO or not put back after the respray guys and attend to anything that was suffering from age related 'illness'
I've also used the time to lubricate all moving parts and replace any odd screw with the correct size. I've also R&R'd all the inside panels and made sure all wiring harnesses are secured and connectors cushioned to prevent any rattles etc. It's all in the detail. I little OCD and time does help.
At the moment, the instrument cluster is out for a new trip gear. This Youtube helped a lot with the 968 style odometer. (
https://www.youtube.com/watch?v=71MKmTKA...e=youtu.be) .
Also busy with cleaning out the wiring mess behind the radio and need to look at the heating actuators, so the center console is also out.
FWIW, here is my snag list: (Almost done)
Replace Passenger side indicator bulb
Replace Passenger side parking light
Central locking actuator alignment
Re-solder lock micro switch wires
Correct Passenger mirror connector pin allocations
Replace snap connectors for roof cover at trunk hinge
Re-align roof top and ensure properly seated
Realign micro switch in hood latch
New armrest hinge
Fit new stone guards
Bend side skirting to fit flush to body
New Interior dome light
New washer pipe T-piece and extension
Trunk lid guides to be turned 90 degrees
Use correct screws for inside rear side panels
Check door guides on frame, turn 180 degrees
Remove overspray on headlight glass
Check hood emblem fastener
Check boot lid alignment
Check glue on hood liner
Fix drain plugs in boot
Straighten bracket in roof gear
Attach rubber hood rests
Sponge cover for power connectors in trunk
Sponge cover for power conductor in hood
Grease window guides
Check missing fixers on window/roof rubber
Check and secure wiring harness in trunk
Check driver headlight alignment
Secure hall sensor in bracket
Tuck in carpet in passenger foot well
Remove dust from inside pass headlamp
Reinforce headlamp brackets
Grease headlight assembly
Check roof mechanism alignment and lubricate
Tie down wires at roof gear
Glue window seals on B column
Clean roof gear area
Remove old CD shuttle cable
Trim and glue vinyl behind seatbelt bracket
Sand and re-spray rusted section under B-pillar
Glue rubber end seal at doors
Glue rubber pad on trunk floor
Shorten screws for window panel
Glue sponge in arm rest lid
R&R seats for clean carpet
Lubricate seat mechanism
R&R Center console
Check heating controls
Replace sponge behind air vent
Insert 5 trim plugs in A pillars
Seal windshield at base to stop wind noise
Glue carpets in trunk
R&R instrument cluster
Replace broken trip gear
Screw in fuel flap stoppers.
Replace clips for cables and washer water pipe under bonnet
Replace driver seat hinge cover
Check light in ash tray
Install new cubby arm
Stick on rear 968 numbers
Glue fan cover at wipers
Clean overspray on engine cover
Check all wiring harness fastening points in engine bay
