968 Cab Restoration
Final result.  Just needs a good waxing.
Skirting problem.
It looks like the support brackets are bent to shit. Are both sides like that?  I would bend them out to make the skirts fit correctly. I don't think the skirts loose there shape as I had one off for a long while with no problems.
Best of luck....the car looks great.
Ryan, those bent metal 'brackets' is what the panel beater put there to fix the skirting to the car.  The skirting should be mounted directly onto the bottom of the car.  The curvature of the good skirting is clearly more pronounced than the bad one.
Yeah that just looks weird. I cannot understand what could account for that. I'm baffled, it looks like the wrong part, to have that bad of a fit. I'll have to look at my car tonite, cuz that doesnt make any sense. Were the skirts damaged, melted!? Car looks fantastic where it counts though :0)
Regards
That panel is really bowed.  They bolt directly to the car underside at 6 spots. On my car the panels are flat between the "recesses" where they bolt to the car. It almost looks like its not aligned to the mounting points.  Did they use all six bolts or did they skip one?
Do you have a picture of the side of the car were we can see the alignment to the upper body?
The car looks great otherwise.
All the clips are new, the alignment is perfect on the side of the car.  Its almost as if the something heavy was left lying on the skirting to cause it to 'flatten' out.  We have had a really hot summer (high 90's) and the warehouse was hot.  Its a complete mystery.  The other side is perfect.
I will try to heat and bend, heat and bend and hopefully get it to realign.
Are you sure it's secured lengthwise (6 bolts) cause it looks bowed between bolts. That must have been a lot of weight to flatten it out. I can't speak about bending it with heat, don't know what heat it would take. Maybe buying a replacement panel would work better if this one is so distorted.
Here's a photo of how the panel fits flush with the bottom on my car.
Would need to see pictures of how the panel fits from all angles on your car to understand how it could possibly have that gap.
I mean, it makes me think that can't possibly be the panel for a 968?
Update: Been busy checking all the nuts and bolts to ensure correct assembly and replace any missing screws etc. I need to still re-align the roof.
Setup to bend the skirting back into shape
After heating with a heat gun, I raised the jack and pressed the skirting up against the chasis.
After heat cycling it twice and leaving overnight,  I removed the jack, inserted the screws and removed the side planks.  The skirting is now flush as it show be. Smile
A while back the adjustment screws on the headlight broke and I never really got around to fixing them properly.  They are not available as parts. Now that I'm going through the car with fine tooth comb fixing and cleaning, I thought I would fix this headlight once and for all.
This is the bracket that holds that headlight and allows for the adjustment of the beam.  Both original screws snapped some time ago.
I took a normal 5mm x 75mm bolt and rounded the head to match the diameter of the original ball, and then polished it. The rounded head, fits snug into the plastic clip. I had to cut off about 10mm from the length to match the broken bits.
The unit reassembled, I used 2 nuts to lock and keep the thread 'loose' . This way the the head light can be adjusted by turning the nuts.
Great idea on the skirts. I should fix mine too. But that will have to wait untill I have the cash to get the entire body sorted.
Yeah strange on the skirts, for some reason I thought they were fiber glass or something.  I do remember reading a long time ago about then shrinking, Mine are shorter and leave a little gap where the front and rear pieces join.
Dit Lyk Gode!
@Type 968 : Lekker!
Nice technique! Glad it worked so well.
With car no longer my daily driver,  I've had time to really work from bumper to bumper over the last 4 weeks and fix anything that had broken, replace anything that was missing from either the PO or not put back after the respray guys and attend to anything that was suffering from age related 'illness'
I've also used the time to lubricate all moving parts and replace any odd screw with the correct size.  I've also R&R'd all the inside panels and made sure all wiring harnesses are secured and connectors cushioned to prevent any rattles etc. It's all in the detail.  I little OCD and time does help. Smile
At the moment,  the instrument cluster is out for a new trip gear. This Youtube helped a lot with the 968 style odometer. (https://www.youtube.com/watch?v=71MKmTKA...e=youtu.be) .
Also busy with cleaning out the wiring mess behind the radio and need to look at the heating actuators, so the center console is also out.
FWIW, here is my snag list:  (Almost done)
Replace Passenger side indicator bulb
Replace Passenger side parking light
Central locking actuator alignment
Re-solder lock micro switch wires
Correct Passenger mirror connector pin allocations
Replace snap connectors for roof cover at trunk hinge
Re-align roof top and ensure properly seated
Realign micro switch in hood latch
New armrest hinge
Fit new stone guards
Bend side skirting to fit flush to body
New Interior dome light
New washer pipe T-piece and extension
Trunk lid guides to be turned 90 degrees
Use correct screws for inside rear side panels
Check door guides on frame, turn 180 degrees
Remove overspray on headlight glass
Check hood emblem fastener
Check boot lid alignment
Check glue on hood liner
Fix drain plugs in boot
Straighten bracket in roof gear
Attach rubber hood rests
Sponge cover for power connectors in trunk
Sponge cover for power conductor in hood
Grease window guides
Check missing fixers on window/roof rubber
Check and secure wiring harness in trunk
Check driver headlight alignment
Secure hall sensor in bracket
Tuck in carpet in passenger foot well
Remove dust from inside pass headlamp
Reinforce headlamp brackets
Grease headlight assembly
Check roof mechanism alignment and lubricate
Tie down wires at roof gear
Glue window seals on B column
Clean roof gear area
Remove old CD shuttle cable
Trim and glue vinyl behind seatbelt bracket
Sand and re-spray rusted section under B-pillar
Glue rubber end seal at doors
Glue rubber pad on trunk floor
Shorten screws for window panel
Glue sponge in arm rest lid
R&R seats for clean carpet
Lubricate seat mechanism
R&R Center console
Check heating controls
Replace sponge behind air vent
Insert 5 trim plugs in A pillars
Seal windshield at base to stop wind noise
Glue carpets in trunk
R&R instrument cluster
Replace broken trip gear
Screw in fuel flap stoppers.
Replace clips for cables and washer water pipe under bonnet
Replace driver seat hinge cover
Check light in ash tray
Install new cubby arm
Stick on rear 968 numbers
Glue fan cover at wipers
Clean overspray on engine cover
Check all wiring harness fastening points in engine bay
Last Post by 94SilverCab
09-09-2016, 02:35 PM
11-18-2014, 10:10 PM
Last Post by mbardeen
12-24-2012, 12:52 AM
Last Post by Sedge
03-22-2009, 05:30 PM
Last Post by ldeprat
10-04-2007, 11:01 AM
Last Post by 968rz
10-26-2006, 09:40 PM
Last Post by Mark
05-17-2006, 10:40 AM
