$100 Reward If You Solve My No Start Problem
Starting with this post, I’ll pay $100 to the first person who pinpoints and helps me resolve (with how-to directions) my no-start problem during the next two weeks, resulting in me getting my 1994 968 six-speed running again. After that, the offer is off and I’m making an appointment with the mechanic. The time stamp on your reply should break a tie if someone is able to help me figure out this puzzle. $100 would be a bargain compared to what I've spent already and may have to spend yet. More information on the problem and what I've done so far is listed below.
Since the t-belt/waterpump/rollers/seals changeout, I’ve tried a dozen things to get the car to start, but no luck. The starter turns the engine over fine, battery good, has 12v electricity to both sides of coil and injectors (but they don’t pulsate or fire), fuel pump works but only if you jumper it at DME relay, etc. but it’s apparently not getting the pulse that triggers the coil or injectors to fire. I’ve replaced with new parts the coil, coil wire, dist., rotor, plugs, cleaned wire grounds (about 8 of them, including the two on top of bell housing), battery terminals sanded and cleaned including small wires, I replaced the reference sensor with new part and calibrated distance to ring gear (about thickness of a dime), checked all fuses, tried 3 diff DME relays, switched and tried another DME controller, checked wires, receptacles, good compression, etc.
There are three things that I’m wondering if they could be the cause of the problem, but there are others I'm sure. What do you think?
1) On the flywheel, there are two sets of marks: “0 | |” marks at one spot then two arrows and three marks at another spot “> > | | |”. Using the small round inspection hole at bottom of front of bell housing, I centered the middle mark of the three horizontal marks (I didn’t use the “0 | |” ). This put the cam gear mark in alignment as well as the balance belt gears “0” marks and cylinder #1 at TDC. I then locked the flywheel in this spot to change belts/rollers. At the time I didn’t see (nor read about) the “0 | |” marks but they don’t seem to line up with the cam gear mark….so…am I OK on this or is timing way off because I might have set the flywheel at the wrong spot? If I did, the settings really didn’t change much if any from before the rebelt job to after…I’m almost certain of this since I locked everything down and marked with paint. I'd hate to move to the other "O ||" and bend my valves. ???
2) Another possibility, there was a pinched wire that I found that goes to the junction plugs just behind the cam gear housing. The Hall sensor junctions here too (BTW, I never messed with the Hall sensor or took the cam gear off). The reference sensor wire has two small wires inside a foil cover and that is covered with braided wire. At the relatively small pinch, I teased apart the plastic, foil, and braided wire and all looks fine. All three are still together although I’m not sure how to verify whether the small wires actually may have a break in them somewhere . They don’t appear to, but I could be wrong. I’m not sure how to check continuity on these wires since they split somewhere and may also go to the DME relay area. Also, resplicing of this wire looks to be difficult but I sure don’t want to replace the whole wiring harness. I need to learn how to troubleshoot this whole circuit I guess. I have voltage/ohm meter but can't use an occilloscope. Also, the trouble/fault codes don't work on my car and I hate to pull the dash and fix that until I get this fixed first.
3) If the ignition junction switch box (round white plastic piece with wires coming out of the back of the key switch) is similar to the 928, these go bad pretty often and, IF the DME gets power from this switch, perhaps that’s another place to look. However, jiggling the switch while cranking usually betrays the problem but it doesn't help my situation.
So…it appears to me that either the reference sensor is getting a confusing signal from the flywheel (see 1 above) and shutting down the triggering signal to coil/injectors…the DME is not getting power…or the sensor wire to the coil area may be broken. However, if the latter, how come the injectors aren’t clicking and putting out gas? (they’re not..it’s dry inside cylinders.) Or are they on the same circuit as the coil? As of today, I know the reference sensor is calibrated right. I've not yet jumpered the Alarm System to bypasss it. Would a malfunction there result in a no pulse situation? The directions I read for bypassing were for a 944...similar but not the same. On the 944 if the sensor is passing on "sensing" the tach needle jumps. Mine doesn't.
What else should I check? I posted a foto of the starter wires and I don’t think there’s a way to hook them up wrong since they really only fit on the posts one way. Maybe there's another wire or ground under there someplace that I need to check? Also, the rotor will only screw on only one way so I don't think that's off, the aluminum spacers are in place, etc.
I’m ready to try about anything at this point. I’ve spent a wad of $$ replacing parts and not any of the possibles I’ve checked seems to be the culprit. I know some of you are tired of hearing of this problem but I HAVE to be getting closer to a solution. Your suggestions are always welcomed. I’ve searched all the archives and have tried about everything…but as some of you have said…”it's probably something simple or something I did while making the belt change” The car did set a couple of months before I got the parts for the work. I know that diagnosing something via email is difficult since you can’t see and you don’t know if I’m a total klutz or not. I built a ’32 Plymouth street rod w/vette engine from the ground up (every frame-up part) and have rebuilt Chevy engines. I’m not great but I’m no novice, although when it comes to electrical stuff, I confess to being a little better than helpless and have to be carefully mentored. Or take it to a mechanic.
I’ve first posted this at 968Forums and 968.Net. Later on, I might post to Rennlist, etc.
What do you think? Thanks.
Harvey
Harvey,
Could you clarify exactly what maintenance operations occured and what parts were changed between the time the car last ran and when it first exhibited this no start condition? Was it just the t-belt/waterpump/rollers/seals?
Brett
[quote name='Harvey' date='Jun 7 2005, 09:41 PM']Also, the trouble/fault codes don't work on my car and I hate to pull the dash and fix that until I get this fixed first.[/quote]
I assume you're talking about the "turn on the key and hold the throttle until the check-engine light flashes" method. Mine didn't work either. Turned out the throttle cable needed tightening just a little; full throttle on the pedal wasn't quite full throttle at whatever sensor it is that makes this work.
Brett,
I pulled the parts off the front of the engine (AC, Alternator), the starter, etc. to get to the belts/waterpump/seals to replace them and install a flywheel lock. I also pulled the cam cover to inspect the cams and pads (all was fine so I closed it up. In doing this, I also had to unhook the fuel lines and plug wires...but nothing else...just put it back together). I also cleaned leaves from underneath the plastic covers over the wiper motor assembly and that area, and fixed a rust spot on bottom of battery box. Since then, I did the stuff mentioned earlier in try to get it running again. It ran fine before belt change but did sit couple of months before I got the parts assembled. I also pulled and checked the relays and fuses and have spares of all of these on hand.
In addition to the ignition related parts mentioned in above post, other parts replaced included the following:
Balance shaft belt (polyrib) 944 102 219 04 $81.71
Camshaft drive timing belt 944 105 232 02 $74.14
Balance shaft tensioner Roller 944 102 025 07 $16.05
Balance Tension Roller 944-102-277-06 $19.62
Intermediate shaft O-ring 999 701 652 40 Two @ $1.97 ea
Timing belt roller 944 105 631 10 $57.21
Timing belt tensioner 944 105 172 03 $83.98
Camshaft belt tensioner roller 944 105 241 02 $27.98
Camshaft belt roller 944-105-241-04 (new number) $27.98
Crankshaft seal 999 113 331 40 $10.77
Crank 0 ring 999-707-283-40 $1.91
Thermostat w/gasket 944-106-019-00 $5.10
Water Heater control valve 928-574-573-03 $46.42
Porsche Remanufactured Waterpump Kit w/thermostat and bolts $174.87
New AC and Alternator belts
Harvey
[quote name='Brett968' date='Jun 7 2005, 08:16 PM']Harvey,
Brett
[right][post="5547"]<{POST_SNAPBACK}>[/post][/right][/quote]
Harvey,
When you turn the ignition key to the ON position do you get "Check Engine" on your dash along with the other warning lights? (Of course, these should all illuminate before the engine is started).
Also, like Pickwick stated you may need to adjust the throttle cable to get the fault code flashing to work. It seems that the cable stretches a bit over time. Alternatively press the accelerator pedal down as far as possible (press extra hard), to see if you can get the fault code readout to work.
Brett
I think that's part of the problem. I do not get the check engine light when I switch on the key. I do see the Air Bag light and others though.
Harvey
[quote name='Harvey' date='Jun 8 2005, 02:44 PM']I think that's part of the problem. I do not get the check engine light when I switch on the key. I do see the Air Bag light and others though.
Harvey
[right][post="5590"]<{POST_SNAPBACK}>[/post][/right][/quote]
Yeah, that's definitely a problem. Although it is certainly possible that your check engine light bulb is out, I would say that giving the symptoms it is considerably more likely that your DME is not coming on. (The DME does not control the other lights on the dash.) This would correspond to the fact that you are not seeing any fuel or spark. So the question is why is the DME not coming on. This is where I would concentrate my efforts.
You already tested another DME, so it is reasonable to assume that the DME itself is not the problem. You said you checked the fuses, so I assume fuse 7 is OK. You can check pin 18 on the DME and make sure it is getting power. It should have 12V at all times (regardless if key is ON or OFF.) The DME relay would also give the exact symptoms that you see but you have already tried this too. I can only assume that you were checking the right relay - G5. Had to ask.
Here is another thing to check. Check for voltage on pin 27 of the DME. With the key ON you should have 12V. With the key OFF you should have nothing. This signal comes from the alarm system. Without this signal the DME will not come on, the check engine light will not illuminate, and the engine will not start.
Brett
08-29-2023, 04:24 PM
Last Post by edm
06-27-2020, 08:42 AM
11-19-2013, 04:36 PM
