05-17-2010, 11:37 AM
Ran my first Autocross Sat with the new M030 bars on. Rear in the middle slot. Didn't have the Yellow Sports on the rear........ran out of time and they needed a week with WD40. Anyway, I was running 2354017 Nitto NT05's on the front and 2554017 05's on the rear. Started at 40 PSI. First run the nose went right where I pointed it but the rear came around really fast. Kept an eye on the tire pressures and kept dialing them down 2 lbs a run with the rears always 2 lbs below the fronts. It got a little better and the times got down to within a second of the perrenial class winner who runs a 944S2 with Khumo Victoracer R-1's, but still fought the oversteer all day.
Next Autocross is this Sunday. I know the rear shocks will help and I'll get them on this week. From what I've researched here, I'm going to move the rear bar to the outermost (softest) level. Does that sound right to eliminate oversteer and promote a little understeer? I think I may have to invest in the lower strut brace also to tie the car together as the Design One upper brace doesn't quite work with a 92 model.............the towers are about 3/4 of an inch closeer than other models.
Any advice guys?
Any advice guys?
