i would START with the lower bar - that is the key to it all - otherwise you are polishing a turd
chassis - stiffening, bracing, yada yada - having these things properly in place establishes what will happen as a result of flex - limiting the flex is the key to limiting the camber change under load
springs (this includes springs, shocks, struts, etc) - these things determine how the car loads itself and how eight tranfers - a 225 is the absolute max for any kind of balance with the stock torsions, and will still make a bit of understeer - adjust the struts for the 225# spring (probably about half way, maybe a touch more) - you'll know it's right when it dampens bumps, but isn't jarring - the compression setting is fixed on those, so no joy there - the rear shocks should not be set more than 1/2 turn from full soft for stock torsions, and has almost nothing to do with the front, though the natural frequencies of the ends of the car will no longer match, and you may find that you have to go 1 full turn from full soft to stop the car from "see-sawing" - this will be at the expense of some jarring in the rear, and a tendency to jump around a bit
brakes - while you might have the 993 brakes in there, even all around, balance is going to be everything - make sure the car is not nose-diving under heavy braking - it should drop nearly evenly on all 4 corners, with just a touch of front bias, and should not lock up the rear - this will establish proper balance going into a corner, which will prevent understeer and oversteer as a result of improper balance and weight transfer
sways - set to accommodate what the car does with the above conditions managed
alignment - set to accommodate tire wear and turn in after setting all above conditions
then go to tire pressures, using a temp gauge, and adjust until you get maximum contact on the tire, while minimize temperature change across that tire
www.968forums.com
