Threads: 12
I've had no luck locating sway bars. I searched in this forum as well as other and also on line. Any hints where these things hide. I'm looking to upgrade from my stock non M030 bars.
Thanks.
P.S. I found Weltmeister but those were out of my budget. [img]style_emoticons/<#EMO_DIR#>/unsure.gif[/img]
1993 Black coupe @ 100K
LWFW + Chip
M030 Sway bars with Delrin from RSBarn
Southboro, MA
(This post was last modified: 04-01-2009, 08:21 PM by
Georges.)
Threads: 167
Call Pete at RS Barn
(215) 968-2599
Threads: 12
Thank you, I'll call Pete. His site was the first place I checked.
LWFW + Chip
Southboro, MA
Threads: 18
You could also call Jason at paragon, thats where I got mine. no affence Pete!
93 midnight blue cab
03 kawasaki zx6rr
03 k2500 duramax
83 944
66 volkswagon squareback
(This post was last modified: 04-02-2009, 12:17 PM by
doster.)
Threads: 12
It's a lot like drivng the 968 for the first time after the winter; you realize how nice a car it is again. I've been away from the forum due to too much work followed by being laid off. Coming back to it after months I remember again you guys are a great bunch.
Thanks Pete. Now, let's just hope that interview next week goes well...
LWFW + Chip
Southboro, MA
Threads: 7
Pete, questions...
delrin bushings noisy compared to M030 rubber bushings?
Do I need the other stuff like the stainless steel brackets since I already have the basic
m030 set up? thanks
Threads: 18
Pete. are the rear drop links you have listed, stock or other.
03 kawasaki zx6rr
03 k2500 duramax
83 944
Threads: 12
Well, months later, no job yet but made some $ doing project work. As a treat I got Pete's package and Flash's delrin mod. I spent Saturday under the car in the driveway; it would have been nice to get 2-3 more inches of room.
Result = WOW. The car is sooo much more precise! It turns much quicker and during the turns adds even more confidence to the car. I broke my street driving rule and squealed all four tires on clover leaves to play with the balance; what a pleasure! Not only does the front work much better but transferring weight to the back feels instantaneous and a more confident grip/transition. I played making throttle micro adjustments inside the turns that were not possible before.
Our last autox event is in 3 weeks and I predict a minimum of 2-3 second time gain. Let's hope for a dry day for a reliable test.
For the moment I stuck the rear sway bar in the middle position. I figured I'll fine tune once I have the chance to get the car at speed (i.e. off public roads).
LWFW + Chip
Southboro, MA
