30mm Sway Bar
This may be a long shot, but does anyone have a m030 30mm front sway bar (hollow)?
You can buy them from Porsche main dealers, about $300
944.343.706.31 $342.00 + Tax
but you need more than just the bar, you will need new drop link bushes and the end clips,
I would replace all the bushes, not just the drop link ones
think you will need the rear M030 Bar as well to balance that car back up
    Check Lindsey Racing also
Thanks for the suggestions! LR may be the way to go. I have a new set of bushings for the 30mm sway and the new dot 31 part number is slightly smaller and is a solid bar instead of hollow so I won’t be able to use theses rubber bushings. The LR version does not need the circlip according to David.
Last Post by blue968
07-19-2017, 09:08 PM
06-05-2016, 09:35 PM
05-11-2016, 09:45 PM
01-27-2011, 10:13 PM
Last Post by bob blackwell
10-11-2010, 08:49 AM
Last Post by Georges
09-20-2009, 07:18 PM
Last Post by kasturbo
05-21-2008, 10:06 AM
Last Post by SILVY968
03-28-2008, 11:48 PM
