02-23-2006, 09:45 PM
Alrighty, I finally lifted my car up to look for the coolant leak. My guess would be the waterpump, but for some reason i cant see up there to tell.( i know i've posted about this before, but my floor jack's hydraulics failed and i just bought a 2-ton aluminium racing jack with a 4-foot handle <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" /> ) When i hooked the pressure tester up it just started pouring out at a steady rate. I've also noticed a small oil leak. I have included two pictures indicating where i can see the coolant leak dripping from and where the oil leak seems to be. Any advice would help. Give me your opinions on where the coolant leak is coming from.
Coolant dripping from here:
Oil leak:
What else should i be able to remove (not the belts, yet) to see where the leak is coming from. It seems to be leaking a bit higher in that photo.
Also, no Oil in the coolant, and no coolant in the oil. Also not blowing any smoke.
Thanks,
Rene
Oil leak:
Thanks,
Rene
(This post was last modified: 02-23-2006, 09:55 PM by Nenehubert.)
