[quote name='flash' post='61112' date='Oct 3 2008, 11:04 PM']i should have mentioned this, as a reference, i have a 57mm offset on my 18 x 9 on the front, which is what you would get with a 10mm spacer on a 67 mm offset rim - i definitely needed alignment correction due to the increased grip - the aluminum nuts were also definitely a no-no with that width and forces increased due to the size - they work fine, and i love the handling, but adjustments and changes were required[/quote]
U mean that stock nuts will not handle the increased grip, or increased weight of the rim&wheel combo? Steel nuts would be boring, because I just love the lightness of stock aluminium nuts!! <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" /> But of course, if there's durability issue with the stock nuts, it's better to have few extra grams on each wheel compared to crashed vehicle and damage done.
I think I'll go with 10 or 15mm spacer front, that should still make wheels fit to my car.
