Threads: 167
Dear Parptarf,
Lesson 1...never begin a post about wheels with "Quick Answer" in the title...that is all.
Threads: 28
What about a 7mm spacer and new lugs?
Threads: 28
I'll have to check, but I have to get them shipped to me from across the country. We know the wheel will fit with 7-15mm spacing, but the problem seems to be the tires.
If I get Spacers that are attached to the hub balance shouldn't be a problem(like 15mm spacers).
Theoretically, running a car with about 1.5" lowering and Koni dampers, I could get a 265tire fit with 15mm spacing. That's judging by a local 958 owner running a similar setup.
Threads: 28
It only has lowering springs on it so then it's probably closer to 1" converting mm to inches is a bit rusty. <img src="/forum/images/smilies/968/wink.png" class="smilie" alt="" />
I have had 10x18" ET65 with 5mm spacer on the car, they had 265/35 tires and they fit like a glove with at least 3-5mm clearance on the outside.
Threads: 28
So 635mm from the top of the arch and to the ground?
Doesn't look like a 295 tire will fit my rears.
Threads: 28
I have 650mm at the back so it's not that low. Maybe a 10" rim at ET50 will fit after all. (ET65+15mm spacer)
Threads: 28
If I only knew the rear spring rate or camber angle. There's not a lot at the back.
Threads: 28
I can try and measure how much clearance I have now. I'm not using ideal wheels but they work as the ones who fit are broken with bad tires.
Now I have a 8x17" ET70 + 15MM spacer at the back, so effectively an ET55. (235/50R17 tires)
The difference in with between that and the 10x18 ET65+15mm spacing with the 295/30R18 tire is 30.4mm on the outside and 20.4mm on the inside.
Threads: 28
Now I feel really dumb. I've used my 5mm FVD spacer the entirely wrong way. No wonder I had balance issues.
Guess I can run the Alleggeritas at ET60 with a different set of tires after all.
Those small screws, or at least one of them, should be screwed into the brake rotor locking screw, right?
(This post was last modified: 06-20-2014, 04:45 PM by
parptarf.)
Threads: 28
That would be my choice too, but you can't have it all <img src="/forum/images/smilies/968/wink.png" class="smilie" alt="" />
As of now I want to test this out with the 295 tire, and if it doesn't fit sell the R-tires and get a set of normal tires with 265 rears. I know that will fit.
(This post was last modified: 06-20-2014, 09:19 PM by
parptarf.)
