Threads: 4
Friend of my is giving me a set of the 993 17" Cup rim with et 52mm in front & et 47 mm at rear. Can any one tell me that this et will fit the 968 or not?
[font=Book Antiqua]S.C. Hung
Threads: 4
[quote name='flash' date='Aug 14 2005, 10:57 PM']yes - my 17" replica C2T rims had those offsets - they push the wheels out about a half inch - very nice stance
make sure you check your alignment - the additional outward offset will dramatically affect tire wear, especially if you have the stock or larger toe settings - if you have one of the performance settings listed in the alignment spec thread (which require the strut tower brace) or something similar, then you will be fine
[right][post="8752"]<{POST_SNAPBACK}>[/post][/right][/quote]
Thnaks! I will check the spec. for the alignment.
