Irrespective of whether or not you have clearance issues (and I'll address that next), it's my personal opinion that these wheels may not look well on your car. Here's some information. On my car I have 18" wheels - 8" wide in front and 10" wide in back. The front are 57 offset, the rear are 58. Since your looking at 7-1/2" width in front, the 50 offset probably would be fine. Here's the math - the 1/2" narrower wheel means the the outer surface of the wheel would by 1/4" further in from the fender. The 7 smaller offset means the outer surface of the wheel would be 7mm (about 1/3") closer to the fender - about a wash. The rear is a very different story. Since the wheel you're considering is the same width as mine, but 7mm greater offset, that would move the outer edge of the wheel that much (again, about 1/3") inside the fender. For my taste, the 58 is already a little further inside the fender than I'd like. My previous rear wheels had a 47 offset and (IMHO) looked great - the outer edge of the wheel pretty much lined up with the fender. However, there was a little bit of fender interference, which is one of the reasons I went to the size I now have.
So - I don't think you'll have any clearance issues, I think the fronts would be just fine, but for my taste the rears would bring the tires too far "inboard". One added point - I'm not sure that I'd want a 2-1/2" difference between front and rear wheel widths on a 968 - I believe that differential is much more appropriate for a 911 where tire sizes are being used to introduce a little relative understeer to counter the massive oversteer that's inherent in the car's design. My previous 18" wheels were 8-1/2" wide in front, and there are some owners that have gone even closer to equal widths front and rear. The 968 inherently is pretty well balanced, and with the 2-1/2" width differential, you could be introducing understeer that you might not like. That would depend, in part, on how you drive the car. For example, if you drive aggressively or participate in autox or DE, that could be a very important consideration.
I hope this helps you make a decision.
