What's this part called?
On front of the waterpump is a plastic fitting retained by two hex bolts with a hose running from it to the coolant reservoir. Does anyone know what it's called and if it's available as a spare part?
I've noticed that it leaks slowly - about a drip a second - and would go a long way to explaining my coolant loss. I've replaced the 0-ring howver it still leaks and I think the plastic fitting may have distorted slightly so that a good seal can't be made. I'm using a 27mm x 3mm O-ring, I tried a 27x2.5 but it leaked like a sieve!
I'll post a picture as soon as I can.
Cheers
Jono
UK-spec '93 Cab, Cobalt Blue, light grey leather interior & sport seats.
Is it #7? It has a 951 part number. I'd try your local Porsche dealer or, if its expensive, Sunset Porsche.
That fitting gets warped and the seal can not be made to hold anymore. It is a cheap part though and easy to replace.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
"Is it #7? It has a 951 part number."
Thanks Mikeo, that's the one! I'll try the local OPC first and then Sunset. I notice Paragon don't have it listed.
Cheers
Jono
Last Post by Heezeg
12-15-2021, 05:29 AM
Last Post by banditsc
11-01-2007, 11:01 AM
Last Post by Kim
04-04-2007, 04:10 PM
