Threads: 5
[quote name='Anchorman' date='Nov 7 2006, 12:12 AM']Practical question - how should one handle a decreasing radius turn? I haven't experienced one on the track, but some highway exit and entrance ramps are like this, and I've been playing with them - at one point, scaring myself a bit, but I'm still here and trying.
[right][post="27615"]<{POST_SNAPBACK}>[/post][/right][/quote]
For a decreasing radius corner I try to plan the exit of the corner and then work backwards. First find a nice late apex that won't cause you to run out of room on corner exit. Then it’s a matter of figuring out how to do the rest of the corner with as much speed as possible while still nailing the late apex you identified and exiting the corner successfully. Often these turns can be broken down into sections where you are hitting multiple apexes. Sometimes an advanced driver can even find enough room to straighten out the car enough for a bit of braking before attacking the final apex.
Jim Child
'94 968 PCA E-Stock/NASA GTS2
'01 Boxster
Threads: 13
93 911 C2 Coupe
