Threads: 2
When I purshased ( from Germany ) a third brake-light kit I asked Dave Greimann
on this Forum for his expert help. He supplied valuable pictures of the lower lip-spoiler cut-out and wiring detail. I was able to fit this mod myself so no special
tools or know-how is required.
However there are quite a few nuts etc to undo and a correct sequence for removal of side channells .hatch spoiler and lower lip-spoiler. Also care is required
in removing threaded screws which can become coroded and turn around without
undoing.
I would advise ordering ALL screws,nuts & bolts ,washers etc to replace at the time of fitting. Also a special screwdriver bit is required to remove the lug-nuts
from the side channells ( I made one myself using a file to cut a groove in the bit )
If the bolt-posts come unglued from the inside face of the side channells then
Araldite or similar will be needed.
Ther is quite a lot of posts on the subject of side channells and hatch spoiler removal ( but not on the third brake-light as this is US spec only ) on the UK Forum
www.968UK.com
Best of luck
Cheers Shaun ( London UK )
968 Coupe Tiptronic.1992 Metallic Slate Grey.Japanese Import.Sport Classic wheels.Goodyear Eagle F1's.Janspeed sports exhaust,M030 brakes,Air-con,Promax Chip,K&N Filter.
Threads: 2
I will reply in a couple of hours....Dont cut anything yet...
Cheers Shaun
Threads: 2
Wrong......You cannot cut the existing lower lip-spoiler.....You will have to order a new US spec lip-spoiler Part No. 944 512 103 03C as shown on PET illustration
803-05 .
For the pictures please see my earlier post and contact Dave Greimann......
His E-Mail is...the engineer@968engineering.com
His Homepage is...http://www.968engineering.com/
Cheers Shaun
Threads: 2
ps. You will also need Part Nos. N 014 123 4 lens-hd screws x four ( M4 x 10 )
I have just found the three photos Dave sent me but am unable to E-mail them to you due to being a computer " numpty " .
If you PM or E-mail me with your address in Holland I will gladly post them to you
F.O.C.
Cheers Shaun
(This post was last modified: 09-21-2006, 01:54 PM by
BBZ 968.)
Threads: 2
Did you receive the pictures ?
