[quote name='jeffm40' date='May 28 2006, 04:25 AM']Is this a common occurrence? I've never seen this issue in any of the threads. It is so good having "968 ENGINEERS" on our board who can identify, engineer and SOLVE a problem in two hours or less!!!
Thanks to all of you guys!
[right][post="21907"]<{POST_SNAPBACK}>[/post][/right][/quote]
Not an engineer, but hate to see $0.10 plastic end up as a $50 NLA part!! All the while the car sits and waits for repairs. I've posted a follow up on the repair procedure and it is simple.
What is surprising to me is that the TIP console looks like typical german engineering except for those silly plastic guides - they are downright flimsy compared to the rest of that assembly and it's a wonder it did not break earlier!
Strangely however, the front giude relies on a plastic "pin" to locate the return spring whereas the rear guide (identical in size and function) has a screw and locknut to achieve the same function as the front! Trust Porsche to have 2 different PN's for the same thing. Clearance is not an issue thankfully.
here's the link to the thread on repairs
http://www.968forums.com/index.php?showtopic=2521
