[quote name='FraMac' post='43999' date='Nov 26 2007, 05:30 AM']I had a similar problem to this - the car had been very slow to crank - thought it may be the battery, but the battery was fine. Occassionally (usually when warm) the starter wouldn't engage, just span over at speed.
One morning I got in the car, started it, and the starter wouldn't disengage - like you I disconnected the battery. I called it a day and got a recon starter. Sorry I can't offer advice, as others have here - just thought I'd let you know you're not alone!
atb
Fraser.[/quote]
Thanks, for the input, sorry for the late reply, recovering from a operation.
I have asked guys in the know more, and i believe i may have the problems sussed, time will tell when i am fit enough to start work on him again.
I believe its the battery cable, it has a too high resistance as the car starts poor first time, (very slow crank speed)if the car is switched off straight away, the car spins over faster second time ( the oil is still cold)
I have heard alot of guys changing the cables for better quality and that is my route, this would explain the starter keeps running, low battery voltage to the starter make the solenoid connections arc, causing them to stick sometimes, hence starter keeps running.
I will give you a update if i am right in a few weeks , god willing
Cheers
Simon
