07-01-2020, 02:41 PM
My 968 has developed an intermittent (but still fairly frequent) squealing noise, most noticeable at low speeds.
Squeal is definitely associated with rotational speed of wheels (not in engine) - see initial video below. I suspect it's related to brakes, but it happens without any brake application. Front rotors and pads were replaced "recently" (a few months ago, but only ~300-400 miles since then). I have taken temps of all rotors after it was happening and there is not enough variation in rotor temp (temps were <5F variance between paired rotors) for me to think there is a specific caliper/pad sticking. The car does NOT pull to either side as I suspect it may if there was a sticking rotor either.
It is NOT reproducible 100% of the time, but happens often enough to be annoying/concerning - of course, one of the times I could NOT reproduce it was when a friend and I were specifically trying to repro it with the intent of further troubleshooting.
Here's a few videos that might help :
Any guesses as to the source? Something brake related? Possible wheel bearing going out?
- Initial time I noticed it (June 1) - https://youtu.be/BRLsZR2Rrss
- Recent repeat occurrence (different location, more open area, slightly higher speed) - https://youtu.be/8n9t12RHpPQ
- Oddly, this video is less than 2 minutes after the above video after stopping at 1 stop sign and one turn - https://youtu.be/tt4UGTs2uqs - note squeal is completely gone at this point (sorry about wind noise). I arrived home less than 2 minutes after this video and squeal was still completely gone at that point.
(This post was last modified: 07-01-2020, 02:42 PM by Velocity.)
