A sudden and very strong shudder at low speed
Hi Folks,
On the way to Detail day west, we were stopped at the light after exiting the freeway. Then turned left, very slow speed, and suddenly the car started shuddering quite violently. Lasted maybe a second, no more than two. It was almost as if the ABS has lost it's mind or the Tip couldn't decide what to do. I immediately threw the car in neutral, we, were on a slight downhill, so I turned the ignition off (steering still working) and we coasted to the median. Lowered blood pressure, then started the engine, all vital signs were good, looked underneath, nothing in sight, slowly placed in neutral, then in drive. All was well from there, drove another 100 miles, no problem, no symptoms. Drove yesterday around town, no problem. Only other thing that day was very hot drive up the freeway, but that is not unusual or this car. Fluids are fine.
I don't think it was the engine, it was not like a miss, but was much more forceful or violent, felt much more like a drivetrain or brake issue. Any ideas? Thanks!
Roland
Roland
when is the last time the MAF was cleaned?
Something similar happen to me. While driving into work I came upon some slow moving traffic, I had the clutch in as I just pulled out of 3rd. As I slowed down I saw an opening in the left lane put it in 3rd and hit the gas. DOH! THe car shuddered very hard then cut off. I restarted the engine and drove up to the next light and as I slowed down the car wouldnt idle smooth. Felt like the engine was trying to jump put. When I pulled into my garage at work I found the problem. A hose had came loose, a vacuum line I believe. I could point it out if I had a diagram of the engine.
<!--quoteo(post=80487:date=Sep 22 2009, 02:15 PM:name=flash)-->QUOTE (flash @ Sep 22 2009, 02:15 PM) <{POST_SNAPBACK}><!--quotec-->when is the last time the MAF was cleaned?<!--QuoteEnd--><!--QuoteEEnd-->
MAF cleaned: don't know, easily 4 years ago or more. So, dumb question (I should look at it anyway), do we have a flapper MAF? I assume it isn't hot wire?
Also wanted to add: this was a pulsing shudder, several times a second, not a one shot. I could be wrong, it is hard to analyze the behavior, but it didn't feel like the engine, when I put it in neutral it purred just fine. I felt more like a binding effect of some type that made the car shake. It was during very slow acceleration, maybe 2 seconds after a full stop.
Roland
Roland
hot wire - not sure if it's the problem or not, but a lot of weird things can happen when it gets dirty
use ONLY MAF cleaner (like CRC), not some other kind of cleaner - do not reinstall wet - do not start until fully dry
My car has done that a few times since I got it (1-2 times a year), it feels like the trans (tiptronic) gets stuck in two gear at once coming to a stop but it never lasts long enough to diagnose (no codes, at least not yet).
Rick
Sounds like a Tip thing to me. I don't know enough about the tip to give advice due to never having had one.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
could be - there is a lot of electronic stuff going on with that thing - sensors and controls a plenty - knock wood, but i haven't had it happen yet on the white car
sometimes cars get attitudes - if all seems fine now, i wouldn't worry unless it happens again
<!--quoteo(post=80500:date=Sep 22 2009, 06:58 PM:name=968rz)-->QUOTE (968rz @ Sep 22 2009, 06:58 PM) <{POST_SNAPBACK}><!--quotec-->My car has done that a few times since I got it (1-2 times a year), it feels like the trans (tiptronic) gets stuck in two gear at once coming to a stop but it never lasts long enough to diagnose (no codes, at least not yet).<!--QuoteEnd--><!--QuoteEEnd-->
Rick, thanks for confirming the basic symptom. Wow, it sounds little scary, not sure what else I can say about it. I sure don't know enough about the tip internals to consider what could be amiss. It is a very complex system, I do worry sometimes that with the ATF going through the radiator (adjacent chamber) that sometimes it gets too hot or something like that.
Maybe as flash said, if there are no lingering symptoms, the we just move on and don't worry about it.
Roland
Roland
yeah - it's like every once in a while one of the cars won't fully start when i hit the key - nothing wrong - it just doesn't kick - flip the key again and good to go - no clue
worry if it becomes a symptom and not an anomaly
<!--quoteo(post=80485:date=Sep 22 2009, 04:17 PM:name=968Syncro)-->QUOTE (968Syncro @ Sep 22 2009, 04:17 PM) <{POST_SNAPBACK}><!--quotec-->Hi Folks,
Roland<!--QuoteEnd--><!--QuoteEEnd-->
I have an Audi A6 Tip that has a similiar intermitent problem. Recently an error code showed up for the torque converter.
Rico Suave
09-26-2022, 01:23 PM
Last Post by Velocity
07-30-2020, 06:45 PM
Last Post by wildcat
05-09-2014, 12:06 PM
Last Post by Byte
08-13-2013, 09:56 PM
