04-30-2005, 09:21 PM
Elephant Racing
I installed these in place of the stock castor blocks which were very worn.
![[Image: controlarmrearmonoballtransparent.gif]](http://www.elephantracing.com/images/monoball/944/controlarmrearmonoballtransparent.gif)
The install was very easy, as we pulled the bolt on the control arm the castor eccentric did not move, hence we did not need to realign the car after install. It took about an hour and we were goofing off.
On the road, there is a noticeable difference, my stock blocks were very worn so this isn't a straight comparison. My current suspension is completely stock with a blown swaybar bushing...anyways back to the road, the first thing I noticed is that the car tends to follow the road and there is slightly more feedback in the steering wheel and in the chassis, you can feel the texture of the surface you are on, both changes are subtle; those are the only cons I have noticed, I would not consider them cons in all cases.
Steering response has improved, the best examples I have are during a lane change, previously at 80 mph when changing lanes it took much more control input to perform a smooth semi-quick lane change, now its a small input to turn and a small correction to straighten the car additionally I got to test it a lot on the way home, I had to dodge a deeply sunken manhole on a newly paved road, the car arced perfectly around and correction was again easy. Over large bumps I did not feel a increase in harshness. The blocks are completely silent at the moment.
I like these blocks, I'll keep ya updated.
(This post was last modified: 04-30-2005, 09:33 PM by mech.)
