Thread Closed
Side Cladding Rubber Replacement
Courtesy of Jeff Coe (jeff968) and Ben Johnson (Spectre996)
A great DIY!
I had this done when my car was in the shop a few years back for some minor body work. The shop did not do nearly the meticulous job you did. I accepted their explanation that the panels warp over time and so it is hard to replace the rubber to an OEM standard. Yet another lesson learned.
Ralph
'77 911S (RIP)
What a great write-up! These guys really set the standard.
anyone know a source for the rubber grommets?
[quote name='xrad' post='52492' date='May 13 2008, 07:39 PM']anyone know a source for the rubber grommets?[/quote]
If you are talking about the little red grommets that attach to the side of the body then you can find them at your local Porsche dealer as well.
thanks. I thought there was a member selling them, too.....seem to remember reading in a post somewhere...
Thanks Jeff - nice write up. There goes another weekend and $100 <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
[quote name='xrad' post='52545' date='May 14 2008, 01:41 PM']thanks. I thought there was a member selling them, too.....seem to remember reading in a post somewhere...[/quote]
That might have been me. I have a few left over. Let me know how many you need. Do you need the studs, plugs, or both?
Every time I read something here it seems to cost me money!
New seals arrived today and the clips and grommets should be here tomorrow (saturday) or Monday.
I have a couple of gaps at the moment and 1 of the front clips is broken, so doing this will make a huge difference.
Thanks for the DIY it will help me no end.
Well, I got the job done! Unfortunately I still had a couple of gaps so both sides had to come back off.
I then discovered that a little "gentle persuasion" on the brackets under the sill made everything fit nice and tight.
Looks much better now and the new goodridge hoses have arrived as well, so another busy weekend.
<img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
tHANKS FOR THE WRITE UP jEFF, MY HUSBAND AND i DID THIS last winter and the new one looked great but it did start to pull out again in the curve. We took it all apart again and used more of the adhesive glue as you instructed looks good now.
Love that color 968 you have
Fantastic write up and I think I will approach this DIY project as well.....on more question however.
In your post, you do not cover the rear cladding which extends from behind the rear wheel and around the rear bumper....this is precisely where the cladding on my car has shrunk and popped out of the channel.
I will check in the forum for more on this topic but any response would be appreciated.
Well sorry for jumping the gun...went back to the forum and there is a post, at least one, on removal of rear bumper, I assume the replacement of the cladding would follow the same process as the side cladding.
Cheers,
Paul
Jeff,
Great write up! You can tell Jeff (and his son Greg) love 968s. This website is really become a treasure for 968 DIY'ers and also for those of us who want to learn more these cars.
[quote name='pmagrath' post='57623' date='Aug 9 2008, 09:26 AM']Fantastic write up and I think I will approach this DIY project as well.....on more question however.
I will check in the forum for more on this topic but any response would be appreciated.[/quote]
I also have the front and rear bumper seals to install someday but they are not usually problem areas. Not like the sides at least. My DIY is just for the more common sides.
Jeff
Hey Jeff,
On your first shot of the small panel being removed, you can see the pin in the clip is ribbed. The replacement clips were not ribbed, but just flared with a recess. The new clip would not hold for me. Did you replace that clip as well? Any problems. I did not replace the body grommets (red plugs) and wondered if that was what needed to be done? Any thoughts?
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Thread Closed
Last Post by Larry Currie
04-01-2008, 10:17 PM
Last Post by SILVY968
02-02-2008, 08:11 PM
