06-25-2007, 11:44 PM
My 968 6-speed just decided to dump its coolant all over the carport this evening (at least it happened as I was arriving home, and not on the climb out of Vegas, as happened to a colleague in her '01 Saab with similar mileage), so it's going back down to Dutch Treat. As long as it's there (I was going to not drive it and get it addressed later)...
Yesterday the transmission gear shift got weird. First, third, fifth, sixth, and to an extent fourth gears are fine, but second feels "spongy," like there's half a loaf of soggy white bread between the gear lever and the gear selector (forgive my terminology). It has also popped out of gear a couple of times, but only from second, and only over rough pavement; with your hand on the shift knob you can feel it "bouncing" significantly more in 2nd (and somewhat in 4th) than in the other gears.
The transmission is relatively new; it's a rebuilt unit that was installed -- oh, okay, so, not so new... It was installed December 2003, about 11,000 miles ago.
The clutch, flywheel, etc., were all done about a month (less than 1,000 miles) ago.
Thoughts as to what it is? Transmission mount(s)?
Thanks!
Thanks!
