Scratched Instrument Glass
Whats the best way to sort a scratched instrument glass, repair or replace? Is it glass or plastic?
It's plastic.
I've used this stuff on headlights/taillights with good results before.
Plan to do same on my instrument cluster too.
The pads / towels you use are just as important as the polish, as to not cause more scratches.
This kit comes with everything needed.
Griot's prices tend to be a little on the high side, but their car care products are quality.
http://www.griotsgarage.com/product/plas...y=ourPicks
novus is the best plastic polish i have found. they make 3 grades.
Believe it or not I also use the commercial blue 3M Superfine glaze on plastic, works quite well. Problem is it comes in a $70.00 a litre bottle so if you only need a bit....
[quote name='DaveN' timestamp='1375298201' post='146298']Believe it or not I also use the commercial blue 3M Superfine glaze on plastic, works quite well. Problem is it comes in a 70.00 litre bottle so if you only need a bit....[/quote]
70 liter bottle? That's over 18 gallons!
... or 3.4 hogsheads!
Ok guys, I corrected my happy fingers!
novus
Same glass as on 944 cluster. Find a 944 cluster of questionable quality at scrap yard, etc. and switch the lens. If the scratch is deep you'll never polish it all the way out.
