SC head O-Ringing
So i have read about this on many other forums and it seems to be a viable solution for people who supercharge or turbocharge their cars - after having head gasket problems. No one has ever broached this subject here so I assume it is not a solution for the type of head/block/compression ratio etc. that we are dealing with here? Maybe it's an engineering thing - not enough room or proper materials?
Dave
i've heard of it being done on a 968 engine. i can't say it's needed. my builder said it was completely unnecessary.
if the surfaces are flat, and you aren't detonating, then there is no reason to think this would be needed.
i am running HIGHER than stock compression, and boost up higher than the standard kit. i have no reason to expect any head gasket issues.
Reading between the lines, was I detonating? <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" /> Could you smell it from where you are? <img src="/forum/images/smilies/968/laugh.png" class="smilie" alt="" />
Dave
The head on my former 968 was milled 11.6 CR, Ported/Polished, O-Ringed, titanium retainers, valve springs good for close to 9K RPM before seeing valve float, and a 3-Angle valve job. All work was done by Powerhaus. O ring is overkill for my application, but the head was already being done....so why not? Some extra safety never hurts.....especially when the motor was spinning at 7,800RPM.
Last Post by Eric_Oz_S2
06-30-2014, 03:04 AM
Last Post by DaveN
01-27-2013, 10:05 PM
