[quote name='Eric_Oz_S2' timestamp='1392633013' post='155151']Mikey
So what do you use on the front with these?
Eric[/quote]
Eric I have had great success with the Koni double adjustable struts Jason also sells.
http://www.paragon-products.com/Koni-944...42conv.htm
Again, there are lots more expensive systems you can try, but these will get you to the same very high skill level as anything from KW for a lot less $.
They are a very capable strut, with adjustable compression and rebound and adjustable ride height that allows use of standard Hypercoils. They can be made soft enough for a tolerably firm street ride, and then all the way to PCA stock class podiums. They don't have all the flashy purple anodized of KW's, but they have the edge in cost vs performance hands down IMO. Much better than the Bilstein Escorts and Firehawk systems as well
If I sound like I'm a bit biased towards steering everyone to Paragon, well, guilty I guess. I've known Jason Burkett for over 12 yrs. His shop has catered to the 944/51/68 variant more than most of the other vendors. He's honest, knowledgeable, and very helpful. As the owner of a fairly successful business, he could take his pick of high strung track toys. He owns the #4 968 Turbo RS for a reason.
Cheers
Mikey
