Threads: 51
I have the 968 numbers removed from the back of my car. There are worn areas where the black is missing. Has anybody got a good way of restoring the color? Paint....what type...best glue for reattachment???
Thanks in advance -Ryan
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 104
<!--quoteo(post=75510:date=Jul 14 2009, 10:42 AM:name=flash)-->QUOTE (flash @ Jul 14 2009, 10:42 AM)
<{POST_SNAPBACK}><!--quotec-->well, any can job is likely to chip pretty easily, but you can try SEM - i think they make a semi gloss as well as the Trim Black - that stuff is pretty tough
as for attachment, i would probably use Krazy Glue or a 2 part epoxy
frankly though, i like it without them emblems - i think it makes the car look wider and cleaner<!--QuoteEnd--><!--QuoteEEnd-->
I agree with Flash on the paint. When I restored my rare edged numbers I used the SEM trim black. Great paint with just the right amount of gloss.
As for attachment, stay away from the glues. You could damage the paint underneath the emblem. You'll want to follow the direction that the factory did. Get some 3M two sided tape. Clean off the bottom of the numbers, then add and trim the tape. Don't paint the emblems until after you have done this step. Then, you'll need to make sure you get a template of how they were on there so they can go back in the same position. Make a template with tracing paper and pencil before you take them off. Then cut out the template, the three numbers together, place it against the car and use masking tape to make note of where the emblem points will go. You'll should have already cleaned the painted surface area on the car so it is smooth. I used the same process above on my car and it came out great. Let me know if you have any other questions.
New replacement emblems are getting expensive. I think someone said they are $40 now?
Jeff
Threads: 104
<!--quoteo(post=75521:date=Jul 14 2009, 12:35 PM:name=flash)-->QUOTE (flash @ Jul 14 2009, 12:35 PM)
<{POST_SNAPBACK}><!--quotec-->i haven't had a lot of luck with the 3M tape lasting very long - it keeps letting go - what's the secret there? maybe it just gets too hot here<!--QuoteEnd--><!--QuoteEEnd-->
Did you get the stuff from the body shop supply store (see photo link)? It is very strong. You can even layer it up if needed. The secret is always just to make sure the surfaces are clean. You'll need a couple of fresh razor blades for the trimming.
http://i9.photobucket.com/albums/a73/jeff9...M2sidedtape.jpg
(This post was last modified: 07-14-2009, 02:30 PM by
jeff968.)
Threads: 104
<!--quoteo(post=75535:date=Jul 14 2009, 03:45 PM:name=flash)-->QUOTE (flash @ Jul 14 2009, 03:45 PM)
<{POST_SNAPBACK}><!--quotec-->holds for a while and then pops off - must be the 100 plus heat<!--QuoteEnd--><!--QuoteEEnd-->
Wow, well, I've never had any issues and I would worry about all your cars being "debadged" by mother nature then. [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
Threads: 104
<!--quoteo(post=75539:date=Jul 14 2009, 04:20 PM:name=flash)-->QUOTE (flash @ Jul 14 2009, 04:20 PM)
<{POST_SNAPBACK}><!--quotec-->debadged is a concern, but not nearly as much as what happens when i leave the M3 outside (black) - one hot day and i have to go and treat the seats - brutal - it's outside right now, as i just had the garage floor redone - ugh<!--QuoteEnd--><!--QuoteEEnd-->
I don't want to tell you what an abnormally cool summer we are having here in New England.
Threads: 104
<!--quoteo(post=75560:date=Jul 14 2009, 08:47 PM:name=rxter)-->QUOTE (rxter @ Jul 14 2009, 08:47 PM)
<{POST_SNAPBACK}><!--quotec-->ANyway, is buffing out as simple as using some light polish and an orbital buffer? Will it really smooth things out?<!--QuoteEnd--><!--QuoteEEnd-->
Yes it will, stop by my house and I'll rub out the scratches for you. Like Bob said, it can be done wrong but if you have the right tools and polishes the scratches will disappear.
Threads: 51
Due to also having the ghost numbers under the old badges, I can not leave them off. The clearcoat was dull around the numbers from years of waxing around the badges. I polished the area, but could not loose the ghost. It is like sharpie that was covered with clearcoat.
What is SEM paint? I have never heard of this brand.
I think Jaeger has the numbers for sale at about $7.00 each. I may look into replacement. Thanks.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 104
