Threads: 11
I assume you mean the rocker panels? Take out the 10mm bolts on the underside and then they unsnap from the body. I would have at least 5 new clips because the are old, brittle and will break. The front pieces need to be unscrewed from inside the fender well, take out the little door that's held in by two screws to access it. It's a very straightforward job.
Steve
1995 Speed Yellow/Black 968 Cab 6 speed
AZ Mobile Detailing
