Threads: 137
Never had this before until they replaced the head gasket and rod bearings. The shop swears they marked everything before pulling it apart.
Brake hard, pulls slightly to the left. <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />
Any ideas on the cause?
I'll probably bring it in for them to look at...
Just wanted you'alls opinion first! <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 8
Did rod bearings on the 944 twice, got lucky enough with "scribing" only one of those times. Assuming all else is normal, you get to buy a fresh alignment. Sorry...
HWFM Chief Marriage Counselor
Threads: 137
Tire pressures are all 36 psi...
Alignment is what I thought! Thanks for the advice...
The shop already said they would align it for free...so that's no biggy.
Michael Sorbera
2002 VW Beetle TDI
Threads: 137
Thanks for all the inputs -
Since I originally posted this, the problem got better a little each day. It doesn't do it at all anymore!
I'm pretty sure that the cause is that the front stabilizer bushing that's near the power steering pump was soaked in oil from the leaking oil pan gasket. Now that the leaks are all plugged up, the bushing gradually lost it's slipperiness.
Michael Sorbera
2002 VW Beetle TDI
Threads: 8
That's an odd one. Well, glad it healed itself.
I suggest you buy two new bushings and replace them. Once swollen from oil, they are shot. Can be done with car on ramps (safer) and a little soap to get those suckers to slide on.
Also, take a close look at your castor block and any other rubber bushings on the A-arm/balljoint on that side. If they are soaked/swollen, you may need to attend to them at some point.
The PO on my car had let PS fluid leak out for a long time. It ran all the way down the rail to the back of the bloody car! This had pretty much trashed the items mentioned above for me.
Threads: 137
I just replaced them two months ago. I'll take a look at them closely this weekend and see if they need replacing.
Michael Sorbera
2002 VW Beetle TDI
