Threads: 17
Did you install new brakepad vibration dampers ?
volvo V70D5 Black
Porsche 968 amethyst
Threads: 45
Most modern pads now come with a anti squeal pad on the back of the pad,
this normally looks like a raised section on the rear of the pad, about .5-1.0 mm thick, covering almost all of the back of the pad, if the pads have this then you try to add the Porsche dampers the pads become to thick to fit in the caliper
I have never use the Porsche dampers, I have no noise from the brakes, the genuine dampers will set you back quite a bit of money
the 36mm ones are $6.50 each x 4, 964.351.096.01
the 40mm ones are $7.00 each x 4, 964.351.096.02
the rear ones are twice as expensive for some strange reason
(This post was last modified: 07-15-2021, 08:45 AM by
Waylander.)
Threads: 17
I always reuse them ,remove ,clean ,ad thin dubbel sided tape , reinstall , never had any problems .
I only have used oem brand pads .
volvo V70D5 Black
Threads: 49
Quote:I always reuse them ,remove ,clean ,ad thin dubbel sided tape , reinstall , never had any problems .
Same here, I pulled out the original dampeners and just removed the dampening material since the pads already had it in their backing plates. Once the dampening material was removed, the adhesive remained, which made them adhere perfectly to the new pads. Two years and lots of miles later, still no squeaks.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 49
I had a similar problem years ago. One of the pads was not manufactured quite right and the pad material was touching the unmachined (rough) part of the rotor. New pads solved the problem.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
