Options for higher octane fuel
What is the best way to run at over 91 octane?
I have no 100 octane suppliers in my area.
I have tried adding one gallon of toluene to a tank, but toluene is $15/gallon and I fill the daily driver every 4 days. Big can = big pain in the a**.
I have seen several octane booster products on the shelf, ie. STP.
What is your collective experience with continuous use of an additive to keep the octane around 93?
Or do the majority of you just run 91? If so is there a preference between Shell, Texaco, 76, Chevron gasoline for consistent quality and injector cleaning ability?
Sunoco Ultra 94???
all the additives do essentially the same thing, but vary in quantity required due to different energy contents - toluene is likely the cheapest route though - the amount of prepackaged booster you need to add is a lot more than you think, and gets pretty pricey
race shops generally carry 100 octane in 5 gallon jugs - a real pain though to drag that thing around though - some have pumps - if you really want to run it, you can get a 55gallon drum and keep it in your garage and have it delivered to you, and use a rabbit pump to pump it into your car (unless you're in oregon)
as a daily driver, i would not worry about maintaining 93 - 91 will give you almost all of your power, especially with a chip (at least the one i am running) - i bump the octane when i am going on a run, but for normal driving, or when i am just doing highway driving, i run 91
i've never run these chemicals into my fuel on a car this new with fuel injections and such - it was no problem on my older carburetted stuff though - i played with acetone, toluene, alcohol, 104 plus, and even jack daniels (college experiment - very bad) - there is a formula for each one (we drank more of the jack than the car got)
as for preference in brands, that is pretty subjective - a lot of people prefer chevron because of the techron in it - i generally run 76 because that is where i get the 100 octane and don't want to go to 2 different stations
I used to have the 93+ octane jones because it just made the car run so much better, but between the chip and adjustable fuel pressure regulator, There doesn't seem to be a performance or drivability gap between 91 and 93.
What I believe is happening is the richer fuel mixture is keeping the knock sensors happy and they are not dialing the timing back as much.
If you feel the car does not run just right on 91, then maybe there are alternatives to "fixing" every tank. One thing that others have had great success with is the injector cleaning service. That really should be the first step to getting full factory spec mixture.
You can get race fuel in the Seattle area. There is a station in Bellevue that had it (don't remember the details anymore). There are pumps at Pacific Raceways. I'm sure there are more places than you realize.
You can always get a small drum or even a 55g barrel and keep it in you garage and mix it in as need be. Andy at Armadillo Racing supplies a lot of ERC gas to racer types and I'm sure he would be glad sell to you too. www.armadilloracing.com
Eric
Thanks to all.
At this point I'll stay at 91, run Chevron for the cleaning thing and go the chip route.
Last Post by unknown4u
09-29-2017, 02:51 PM
08-05-2016, 08:54 PM
Last Post by DaveN
07-25-2013, 04:30 PM
