09-29-2013, 08:38 PM
I'm 99% sure I need a new starter, but I figured it wouldn't hurt to bounce my symptoms off the collective wisdom of this forum before ordering a new one.
The car started normally on Friday when I drove it to work, but when I tried starting it about two hours later to go to my physical therapy appointment (for a herniated disk - so much fun...), the engine wouldn't crank one iota. The power windows, lights, windshield wipers, etc., all worked. It just made a sort of clunking sound when I turned the key to the start position, but there was no sign of any cranking of the starter.
So I had it towed home, and put a charger on the battery, which I then took in to get tested, and it checked out as being in perfect condition. I also checked relays G2 (ignition relay 15) and G14 (ignition relay X), and they are working perfectly. I didn't check relay G22 (anti"block" braking system), however...
Anyway, I next got under the car while my wife turned the key to the start position, and I could hear and feel a loud clank within the starter, which I presume is the starter's pinion shaft smacking into the flywheel ring gear. I tried smacking the starter's body with a hammer to see if I could loosen up the motor assembly, but it still won't turn. Finally, I turned the engine by hand, and it turns with normal effort, ruling out the engine being seized up.
From the description above, is there anything else I should test before ordering a new starter? Would it be worth removing the starter with the cables still attached, and seeing if it turns when turning the key to the start position? I've never tried that, and am wondering if there's any risk, and if it's worth doing, or is it pretty conclusive that I need a new starter? Thanks.
Sold
