Welcome,
You will love your 968, if the maintenance is up to date.
Timing Belt/Balance Shaft Belt, not only how many miles ago, but when? (More than 5 years, don't even start the car until they are changed).
Leaking power steering hose on the passenger side.
Most of the rubber parts are probably toast by now, if they haven't been changed (stuff like castor blocks on the A arms)
This is a Tiptronic, right? The flex dampners are known to tear, you will feel vibration before it goes. WHEN it goes, it is expensive to fix (not exactly sure, but figure $3-4K by the time you're done, someone with a Tip might be able to estimate that better).
Cosmetic bits and pieces are probably going to look pretty nice on a 28k car. I would expect a bit of wear on the driver's seat bolster.
