Threads: 137
I'm afraid to tell you yes just by electrical knowledge - theoretically, yes. But you know how Porsche's are, they just never seem to be theoretical!
I'd wait for some confirmation - you can blow the ECU if you goof up.
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 14
Speaking as a qualified electrical engineer (ala 'sparky' <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> ) while not claiming to be an auto-electician, but owner of an Australian 968CS with battery in left rear corner, I believe you would be adding a couple of unneeded kikogramsby running two battery leads to back of the car. After all the huge amount of metal in the body offers very low electrical resistance and you will have no issues
provided you create low resistance the connections (as you rightly discern)
In my car the negative lead runs for 6 inches from battery to a (factory) 13mm hex bolt into the bodywork. (Your car may even have same unused connection point - not sure if US cars have the battery tray behind LH read wheel?) I haven't looked closely at starter connection wiring but I could take a peek or even a photo if its useful to you (in next week or so I'm planning to refurb my starter motor). But I don't expect to find anything special, just another solid cable connected to bodywork.
So just make sure every connection point is solid with very low resistance. Preferably bare metal-to-metal with some corrosion-resistant conductive goop smeared on it (your Auto electrician should have some). I wouldn't fret over the galvanising, its only Zinc coating after all.
sparky
Porsche #1: MY03 Boxster S (sold)
Porsche #2: MY94 968CS red (sold)
Porsche #3: MY94 968CS M030 white (fast!)
non-Porsche #1: MY91 Acura NSX (not bad for a non-Porsche)
(This post was last modified: 12-29-2005, 08:53 PM by
sparky.)
Threads: 14
968gene
yep, she's a track car alright. Wheels are 2003 Boxster S 17x7 17x8.5 (offsets 55F 48R) With additional 17mm spacer on front they fit perfectly, and they're a few kgs (oops, I mean lbs) lighter than stock CupII wheels. (and IMHO they really suit the car). Here we are in our big debut in Classic Adelaide this year ....
PS: flash, I'm sure electons do spin the 'right' way down here <img src="/forum/images/smilies/968/dry.gif" class="smilie" alt="" /> but I'l go check on a few !
sparky
Threads: 14
[quote name='Cloud9...68' date='Jan 1 2006, 02:35 AM']Flash,
Just a thought, but as an alternative .. replacing your battery with an Odyssey dry cell[right][post="13961"]<{POST_SNAPBACK}>[/post][/right][/quote]
Or .... you could do both!
In fact I have the Odyssey PC680 in back corner of my car. Weighs just 15lbs ( saving around 22lbs over stock battery). It starts car just as well as stock
but it does have less storage capacity so essential to have zero overnight drain, and give it reasonable drive / charge time vs usage with motor off. For example mine struggled one day at a wet motorkhana event, lots of short runs, engine on/off, using wipers without motor running etc But it was fine after the drive home. Also keep in mind things like security systems. I have removed all such luxuries.
Also they are a much safer battery, completely sealed = no holes = cannot leak (e.g. they're allowed as freight on commercial aircraft unlike most batteries) and can be mounted at any angle.
Here's their official comparo table. PC 625, 680, 925 all candidates:
Odyssey Battery Specs
sparky
(This post was last modified: 12-31-2005, 08:55 PM by
sparky.)
