Threads: 51
I am using an Alpine V45 amp (4x45) I think.. with 6.5" in the front. I am not using the rears. The fronts are JL Audio separates and I use the second 2 channels of the amp for a 10" tube sub and they sound great together.
6.5" will work with a cab, but like Flash said, I don't think in a coupe.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 51
My car is a cab, but the 6.5" speakers are down low as far forward as possible. The parcel pouch partially cover them, but the sound is not affected in a negative way. The panels had to be modified, but it was done by the <acronym title='previous owner'>PO</acronym> for another set of drivers before me.
I have a 10" Bazooka tube (passive) and use 2 of the amps channels mono to drive it. The system rocks! My tube is in the trunk and takes up a fair amount of space, but thats life.
I have an infinity bass-link in my truck that may be great for a coupe as it takes little space and really puts out the sound for such a small size. Worth a look.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 15
Flash is correct, a 6.5" driver will not fit in the forward map pocket position in a coupe. The front window channel runs right behind where the speaker is, so there is not enough depth for a larger speaker. You can fit a 5.25" speaker in the under-armrest location, which isn't ideal position-wise as Flash stated, but there are virtually no 3-way systems available that include a 4" mid (for those of us with the 10 speaker option).
-Austin
'94 Black/Tan Coupe
Threads: 15
I'm running a 5-channel amp with the KLA sub box in the passenger side cubby. It's definitely not enough. Next step is to try the JL 8" sub that Flash recommends, as it's supposed to go quite a bit lower than the Polk unit I currently have. If that doesn't work I'm going to ditch the KLA box and seal up the entire cubby with dynamat and a 3/4" <acronym title='dual mass flywheel'>DMF</acronym> lid to gain air volume. If that doesn't work I guess I'll abandon my 'it must be out of sight' rule and try a sealed bass tube.
I also have the boomy resonance from the rear speakers. The cure for this is Flash's foam fill mod along with some dynamat. I'll definitely be getting to this as soon as the sound from my current system sufficiently pisses me off!
-Austin
'94 Black/Tan Coupe
Threads: 15
I agree, Flash. I'm going to basically do what you suggested and then hopefully leave it alone. Forever. And get back to getting the car off the DL.
-Austin
'94 Black/Tan Coupe
