06-04-2005, 02:43 AM
A couple weeks ago, I noticed cylinder 4 was running a bit lean. I decided to send in the old injectors and change plugs since they were do again. Just thought I would share my results.
Injector type: Sat. 15.5 Ohm
Test pressure: 43 PSI
Test pulse: 6.0 MS
Injector make: Bosch
Gravity Weight: 0.75
Injector 1 2 3 4
Before: 72.9 71.1 68.6 71.4 Difference: 6.3%
Spray Pattern: OK OK N/G OK
Reverse Cycle: Dirty Dirty Dirty Dirty
After: 75.9 75.2 75.9 75.9 Difference: 1.0%
Spray Pattern: OK OK OK OK
Leakage Test: Good Good Good Good
All injectors within specification after cleaning.
I'm very happy with the difference. Acceleration is much smoother all the way to redline, and since that spray pattern on that injector 3 is fixed, I will no longer be running a bit lean in that 4th cylinder. I figure it's good for about an 8 horspower gain (or should I say re-gain) or so. I can definately feel the difference. It was well worth the money, and highly recommended.
Test pulse: 6.0 MS
Injector 1 2 3 4
(This post was last modified: 06-04-2005, 02:46 AM by rustech.)
