07-04-2007, 04:24 PM
I wanted to introduce myself and my car to you guys. My name is Dino, i'm from New York City. My car is a 1995 968 Coupe.
Aside from the modifications, i did a lot of maintnance to get the car up to par while the engine was apart. PS pump, all Belts, Cam Chain, tensioners, front engine seals, rear seals, full tune-up, water pump, suspension bushings, swapped the old foggy fog lights for new ones, new rod bearings, main bearings, head set, block set.
These are the modifications that have been done thus far....
Exterior
-AIR 968 Turbo S Front Splitter
-Euro Spec Front Turn Signals (Bumperette Delete).
-18" 993 Turbo Hollow Spoke Technology Wheels (re-finished in Paint Code: VOL932-Volvo 850 R Anthracite). 225.40 18/285 30 18 Michelin pilot sport tires.
-AIR 968 Turbo S Adjustable Rear Spoiler (Carbon Fiber).
Drivetrain
-PowerHaus 12.5LBS Billet Flywheel (OEM Flywheel: 30LBS).
-Head Rebuilt by PowerHaus: has been Ported/Polished, O-Ringed, 3-Angle Valve Job, Milled to 11.6:1 C.R. up from 11.0:1, High performance valve springs(good for 8000RPM), new retainers.
-PowerHaus Stainless Steel Head Gasket.
-Custom Ram-Air Intake System (9 Magazine).
-RS Barn Stage 2 Chip (Re-Mapped: 7700RPM Rev-Limit up from 6700RPM).
-Stuttgart Shift Block.
-RS Barn Equal Length 4-into-1 Header.
-RS Barn High Flo Cat.
-RS Barn Cat-Back with Reverse Flow Muffler.
Suspension
-Koni Adjustable Yellow Shocks & Struts.
-H&R Springs (1" drop up front)
-Factory Rear-Ride Height Adjustment (3/4" drop in the rear).
-KLA Strut Tower Brace.
-RS Barn (Flash) Chassis Brace.
-Custom Alignment (Corner Balanced with me in the car).
Future modifications
-RS Barn Camshafts
-Dyno-tune & Re-map with RS Barn Software
-RS Barn 968 Sway Bars
-993 Big Red calipers, pads & discs up front. SS brake lines
-MO30 968 Discs in the rear with ferodo brake pads
-LHP ITB's
The Car is in the shop currently, i was rear-ended several months ago and have been lazy to take her in. The damage wasnt bad as it was a light hit, but hard enough to crack the corner of my bumper. None of the panels were touched. So i'm getting a new bumper installed as well as the new Rear spoiler clear coated & my header/exhaust/chassis brace installed. I'm also refinishing the front splitter as it has a bunch of stones chips & scrapes on it from being so low. I will be back to update this thread with Pictures of my car once i get it out the shop and do a photo shoot.
If anyone has any questions or comments, feel free to ask. Here are a couple pictures of the car prior to the photoshoot i will do with my new spoiler & exhaust.
Exterior
Drivetrain
Suspension
-RS Barn Camshafts
-LHP ITB's
(This post was last modified: 07-05-2007, 02:31 AM by Fox944.)
