Threads: 77
So since I'm getting ready to put a few miles on the car in the next week or so, I decided I would tackle the noisy and not so sealed top. The main rattle that was annoying me was where the cab top meets the windshield. I started with adjusting the locking mechanism so it would clamp down with a little more force, but that didn't help the rattle. The issue is when I hit bumps and the top rocks side to side, the locating pin is clanking around inside the receiver. I noticed the pin doesn't actually go all the way down inside the receiver, it's far from it, so it has room to rock back and forth and clank around. So my simple fix for that was to put a zip tie in the receiver, which makes for a much tighter fit for the pin in the receiver eliminating the noises.
This fix may or may not work for those of you still in power mode for the top as it may get in the way of the micro switch in the receiver, but you could probably position the zip tie away from it. All you have to do is loosen up the trim panel enough so you can get the zip tie in and your done.
Threads: 77
Sort of, I did tighten down the latches and that fixed the downward pressure issue, but that didn't fix the left to right movement the top makes when it hit's bumps. It's metal on metal and moves around, wouldn't have thought Porsche would do something like that without a plastic insert or something to stop the metal on metal noise.
Threads: 77
I could take a pic, basically I put it thru the hole out the bottom and put the zip tie together.
Threads: 77
I suppose mine could be a little worn out maybe?
Threads: 77
The shrink tubing was my first attempt, I thought it would work well to stop the noise. The problem is they worked there way off the pin pretty quickly and just jammed up in the bottom.
Threads: 77
You really can't see it, only if the top is down and if you know it is there. I probably ought to price out the cost of new pins and receivers, but I probably don't want to know what that is.
