The Battery Tender continues to be awesome. Today began with a cold start at 6:30a so about 50F ambient and the starter cranks with as much power as the old lead acid battery. I drove about 5 minutes away to pump a couple gallons of fuel, started the car again then drove 5 more miles to pick up a friend to autocross with me today. Started the car again and drove 45 minutes to the autocross site at Alameda Naval Base where the Myth Busters TV show is hosted. Now begins the good part...
A dozen additional starts at 75 ambient, all with the same power as the old battery. Basically started the engine, warmed it up, did 1st autocross run, let engine idle for a minute while measuring tire temps, then shut the engine off. Repeated this for my 5 autocross runs, turned off the car, then my friend did his 5 autocross runs in the next group, shut engine off and started again in between each lap. After each of my autocross laps I used my IR digital thermometer to take the battery case reading and it was ambient every single time. 72 degrees, 76 degrees, etc etc. My buddy drove back to the paddock, turned the engine off and we packed up for the day, then I started and drove 5 miles for fuel and started one more time for the drive home.
The 968 drives great with 50 less pounds in it and I've very pleased. I'm done driving this car now for several weeks so we'll see if the battery has any problems holding charge for that period of time. I may buy a trickle charger, we'll see.
I'm going to start on a better mount in July so we'll see how that goes but the proto mount worked perfectly today - SO STOKED!!!
