Threads: 5
PCA F Stock 968's run 2:14 to 2:16. I don't know what your prep level is, but anything under 2:20 is pretty quick for a 968 at the Glen.
Jim Child
'94 968 PCA E-Stock/NASA GTS2
'01 Boxster
Threads: 20
I was there, no data, but ran my fastest yet with a great instructor (Jim Briggs from Ohio) He had me passing some significantly faster cars. Unfortunately when I was signed off I became significantly slower! <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" /> It looked like Pablo was running some fast laps with a car prepped by Pete.
Great event!
'94 Coupe, midnight blue, grey leather, 6-spd,
airbox mod, RS Barn Stage 1 Chip. KLA strut brace
"Too much is always better than not enough."
-J.R. "Bob" Dobbs
Threads: 7
Vaino, with your cars prep level I would say that the car is capable of running high teens. There are a lot of little things at the Glen that add up to big differences in speed. Hopefully my car will be ready for NNJR's WGII event and I might be able to get you some times for a nearly stock car.
'92 968 ~ Amazon Green Coupe, 6spd, LSD
Threads: 30
What an awesome weekend indeed! Outstanding to see all of us running the 968s at speed and all looking great.
Vaino; I am no expert in lap times but you certainly looked very well out on the track the few times I was able to watch you. I may have some video and pics I'll try to post later.
Bill: Congrats on your signoff! Its great to see you drive so well! Cheers!
Indeed, Pete was out in full force and helping me shake down the car (and driver!) he has been building (I think we are finally on the right path to get him back out on the track more consistently - has something to do with the right breakfast sandwiches!) . I did not have a data system so no idea on lap times. But the car was running very strong for its first outing and given the slow rookie driver. The car is probably good for great laps but then again, I may have been able to pull a lap every 5 minutes! :-). I will start a thread when I have a chance to track the progress of the car (and driver) with the goal to see another 968 representing in NASA and PCA Northeast and Mid-Atlantic races by early 08.
Maybe Pete will let me get a Traqmate by next outing if I beg enough :-(
Pablo
#75 RS Barn-Hoosier-AJ Hartman Racing Porsche 968
2012 PCA GT5S NORTH ATLANTIC CHAMPION
2011 NASA PRO RACING (NE) GTS-2 CHAMPION
Track Records: Pocono Long Single Infield CCW | Pocono Double Infield | NJMP Thunderbolt w & w/o Chicane | Lime Rock Park
Threads: 5
Make sure you're going flat out from turn 1 all the way to the bus stop. No lifting in the esses. There is also tons of speed to be gained in the bus stop. Make sure you're not overslowing the car as you brake for the it. You can carry tons of speed into and out of the bus stop. There's also lots of speed in the carousel. Once you get the car turned in the banking will support full throttle all the way to the brake zone for turn 6. Try not to overslow the car for turn 6. For turn 10 you only need a lift, or a very small brush of the brakes. Don't brake hard for the corner. If you do all of those things you will see a sub 2:20 lap.
Jim Child
'01 Boxster
Threads: 5
[quote name='Vaino' post='40301' date='Aug 23 2007, 05:36 PM']Curious. What tires and brake pads are you running? What kind of G's are you seeing? I peak corners at 1.3G, and braking is 1.18G. Tires NT-01, and brakes Hawk HT-10s on 928S4 rotors/brakes. Stock roters/brakes rear. 928 Brake Bias valve.[/quote]
I run Hoosiers and Hawk HT-10 pads. Last time I was at the Glen was in 2005, and I may have been using Pagid Blacks at that time. I don't have data in my car, so I can't give you exact speeds and G's. My car is maxed out to the PCA F-Stock rules, with double adjustable suspension, etc. running at around 3,250 lbs with driver. My best time from 2005 is a 2:16. I'll be disapointed if I can't get into the 2:14-2:15 range with the car in its current trim the next time I go.
Lifting for turn 2 is killing your times. Going flat through there is worth at least a couple of seconds. You say if you hit turn 2 too hot you end up too far left to line up for the esses properly. There are two ways to fix that. First make sure your line into turn 2 takes full advantage of the banking in that corner. Walk the track if you get a chance, and you'll get a full appreciation of how much banking there is there and where you have to be to hit it best. Walk through the corner and turn around and look back at it. Second, if the car is understeering in spite of being on the right line, then try to dial it out. Try stiffening the rear a little bit with whatever adjustments you have available.
Going flat through that section the first time is a real white knuckle ride, but after you do it once it becomes much easier. Its one of my favorite sections of track anywhere.
Jim Child
'01 Boxster
Threads: 5
I always use 5th gear, and then downshift to 4th for the Bus Stop. If you're using street tires, try 40 lbs hot pressure. Start around 32 cold, then bleed down to 40 lbs after your first run if necessary.
Jim Child
'01 Boxster
Threads: 20
5th on the back straight. I am not quite up to flooring it thru turn 2, although I do in the esses. I stay in 4th on front straight.
My goal next event is much more speed outta turn 1 thru 2!
-J.R. "Bob" Dobbs
Threads: 6
Hey Jim, Hope all is well, where do you buy the Hawk Pads from and how do they compare to Pagid Blacks? Thanks!!!
Lou Lipari
1992 968 Firehawk
PCA Nationally Certified Instructor
PCA Suncoast Region Past President
(This post was last modified: 08-31-2007, 08:44 PM by
Nine68.)
Threads: 5
[quote name='Nine68' post='40645' date='Aug 31 2007, 11:43 PM']Hey Jim, Hope all is well, where do you buy the Hawk Pads from and how do they compare to Pagid Blacks? Thanks!!![/quote]
I get my Hawks from raceshopper.com, but there are tons of Hawk dealers out there. I used to use Pagid Blacks, but my last two sets caused material transfer and lethal brake judder despite careful bedding. The Hawks are extremely user friendly. They work great right out of the box with no complicated bedding process. I find that they perform as well as the Blacks.
Jim Child
'01 Boxster
