Koni Shocks
Hi
I'm wondering if any of you out there have any Koni yellow from a M030 out
in the Garage that you don't need anymore. Looking to get a set of custom valve
double adjustables made by koni, they don't have the bodys for them anymore.
that is why i'm looking for a set.
I plan on doing a Lot of National Scca autox's with mine, Know that they moved out the S2000 and Base Boxster to A-stock. It makes the 968 one of the cars
to have for national level events. I ran my 968 for about 4 years before retiring
it from autox. <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" /> At that time I sold my wheels and Shocks. Know I need to get them back.
1994 968 coupe polar silver 200K "greyghost"
2004 Boxster S 550 SE "box"
1993 Miata le "blackie"
2002 Yukon xl 4x4 502ci "Kong"
[quote name='RCS968' date='Feb 3 2005, 04:36 PM']Hi
[right][post="173"]<{POST_SNAPBACK}>[/post][/right][/quote]
[quote name='bob blackwell' date='Feb 4 2005, 09:40 AM'][right][post="209"]<{POST_SNAPBACK}>[/post][/right][/quote]
Rob, do you want the front or rear Koni Yellow Gas Adjustable shocks? My friend Bill Oaks has a set of rears that he is not using and will probably part with. Good luck, Bob Blackwell.
I have a set of Konis off a 89 944TurboS. The bodies should be identical except slightly different part #s. They are fire damaged but are probably useable as cores for a rebuild. That is the only reason I was keeping them around. Let me know if you want anymore info.
Eric
[quote name='Eric_K' date='Feb 4 2005, 11:42 AM']I have a set of Konis off a 89 944TurboS. The bodies should be identical except slightly different part #s. They are fire damaged but are probably useable as cores for a rebuild. That is the only reason I was keeping them around. Let me know if you want anymore info.
Eric
[right][post="211"]<{POST_SNAPBACK}>[/post][/right][/quote]
hi Eric
Yes, please I would love to get hold of them. If that fine with you what do you
want for them.
email robfalkner@aol.com
cell 704-689-0695
thanks Rob
I will email you some pictures of them this weekend.
Eric
Rob, I have a pair of rear M030 shocks off my M030 coupe. One is weak, so they a perfect for rebuilding. Let know if you are still looking. Dave
12-03-2012, 11:15 PM
Last Post by mdss
12-28-2011, 04:19 PM
12-06-2011, 11:44 AM
Last Post by jaap
04-04-2008, 05:05 PM
