Installing temporary clear auto wrap material
As promised here is the write up on this temporary clear bra stuff. But first, let's start with a reason to put something on the front of your car before you hit the road for some R&R.
Yes, that is a nail that landed sideways on my car. The head cut almost all the way through the vinyl bra. The lesson here is that while a permanent clear bra is great for everyday driving, when you are headed out on the mean highways for extended exposure to trucks, construction zones, and god-knows what else, put a decent vinyl bra on over your clear material.
To the clear stuff. They sell the wrap in rolls and kits and such. I got the 18" roll and used a box cutter. The razor blade cutter thingy they include with the wrap is useless - put it in the recycling bin and put a new blade in your exacto knife.
Directions say put the stuff on side to side - i.e. horizontally. Well, naturally I don't read no stinking directions and so we put it on the hood front to back. Like so.
My advise - follow the directions. Its a bit hard to see in this picture, but at freeway speeds the material on the hood ballooned, badly (you can sort ot tell as the hood profile looks more like a PT Cruiser than a svelt 968). You can see that we tried to tape it down repeatedly during pit stops - to no avail. I also recommend that you tape the mirrors - the wrap covered well, but it flapped around a lot and we ended up taping it all down on teh mirrors later.
So the next day we redid the hood. We started at the top - did the corners of the hood actually, then applied in strips back to front, so that the overlap is kept down by the wind, rather than peeled up. And - the applicator is important. They sell a felt covered plastic thing that helps you apply the film properly. I did not have that with me so I used a washcloth from the hotel (shhh....) and it worked OK, but not great. But, it worked well enough. You can see that the material is pretty tight on the hood on this, second application. It stayed that way for the next 2000 miles.
An important tip (included in the directions, btw) is to not apply to dirty bits (under the hood, in the wheel wells). It will just lift off, almost immediately. I got a bottle of isopropyl alcohol and cleaned off the underside of the hood, let dry, and wrapped underneath. It is critical to do that as much as possible. If you don't wrap around the edges the stuff will start to peel up after 20 minutes at 70 mph.
Here is a pic of wrapping around the door jamb - same idea.
Something else that we found was that before you apply its a good idea to wipe the area down with isopropyl to remove the wax. This stuff won't stick to wax, period. Notice how the wrap has pulled off the side cladding completely.
Once we removed, wiped down with IPA, and applied new material it stuck much better.
Finally, you can see that we used a lot of painters tape (3M FWIW). The stipes on the fenders are not for show (although they are very racy looking [img]style_emoticons/<#EMO_DIR#>/wink.gif[/img] I put those on to control the ballooning (same bad front to back application as the hood - but I ran out of material to replace). We also needed to tape down a lot of edges. This turned out to be a very important aspect.
Rolling down the road we would hear a piece here or there flapping around. We got tired of stopping and repairing and so started to ignore it and retape at the next scheduled pit stop. Mistake. The sound you hear is your clear coat grinding away. Also - taping over an area of poor adhesion is OK - but you need to remove the part that is not adhering, clean it with IPA, then tape. The wrap is slightly adhesive, and a loose piece will trap road dirt. If you tape that to your paint it will sand away your clear. So I had a bit of buffing to do in a couple of spots, but nothing that was unrepairable.
Was it worth it? Absolutely. When we peeled the stuff off in the garage 2700 miles after application, the paint was clean and unharmed in any way. It also allows you to put a vinyl bra on without concern about sanding the clear. I'm putting it on the Van as I am picking up my son from his freshman year tomorrow - some seriously large bugs on that trip.
Kudos. Brilliant idea to have had this done !
Rxter, who sells this stuff? Thanks
Jeff
This is site I used.
http://www.buyroadwrap.com/
When I fist saw this, it looked like spy photos of some new model car.
Personally , I would just purchase a car-condom....[Image: laugh.gif]
ya know, you can clear bra the entire car - i saw it done on a carrera gt and it looked pretty decent - that car was silver, and the paint wasn't as reflective, but other than that it was fine
the problem i see with the wrap stuff is that part of the fun of a road trip is showing off the car, and that makes it look pretty goofy
still, i did something similar on the way back from the denver run, and it was extremely effective
I have to say that I got into a lot more conversations with all that stuff on the car than I would have otherwise - some of them less pleasant than others. "Hey gramps, you got plastic stuff all over your car" and "Yo dude, your car looks like a snot-rag" or, "I didn't know they made condums that big".
Also had a very concerned gent in a rest stop wander by as his head cranked around. On his way out of the pit stop he just had to ask "is everything OK?" in a very genuine and concerned way. We laughed and talked for 10 minutes - a highlight of our trip.
We are heading out in a couple of weeks and the car will look pretty much the same. I am looking for different colored painters' tape though. Ferrari red might look really good.....
Thanks Rxter, I'm going to do the drive to Savanah GA from CT for the Parade in a few months and want to use the stuff. I know Groits garage sells a similar product.
BTW, I tried to send you a PM but you mailbox is full.
Jeff
Those are the kinds of comments I'm trying to avoid as I travel to Long Beach. I still want my car to look nice, how pompous and pretentious of me <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
I have ordered a bra from Sunset and will have it delivered to my destiantion so at least I can "wear it" on the way back. FYI they told me there were none in the country or in Germany but ordering it from Porsche might scare one up. Odd to note too that the bra is 81.00 + shipping to anywhere but OR. If I pick it up in OR on my way through I have to pay 106.00 <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
09-19-2021, 11:39 AM
Last Post by Tom030
06-03-2010, 01:25 PM
Last Post by Fox944
04-19-2010, 02:53 PM
Last Post by seattledl
09-20-2009, 06:25 PM
Last Post by gryphon
06-20-2009, 08:51 PM
Last Post by Mark
08-27-2008, 08:27 PM
