08-01-2011, 02:18 PM
i just can't leave this alone - i have been wrestling with the sound system in the blue car for 7 years - i have tried a half dozen decks, 4 sets of speakers, different subs, external eqs, filters, and all sorts of stuff - finally i'm close, but i'm still not there
the subs are working pretty well, and i can leave those alone - i think the rear speakers are now going to be fine too - the head unit finally makes me happy (since it is the same one i have in the other 2 cars i drive) - the problem is the front speakers
well, it's not actually the speakers themselves - those are very nice units - they are kenwood 5.25 woofers with 1" tweeters and an adjustable crossover - by themselves they sound good - the problem is the location they are in - i have been trying to work with it, as i did not want to cut into my panels
the 968 has HORRIBLE speaker placement - the woofers are at your hips - my hips don't hear that well (which may explain why i'm not on "so you think you can dance") - they are also way too far away from the tweeter for decent sound field imaging - they should be no more than 8" away from each other - this makes for a very difficult to tune setup - it gets even worse in a cab - at least in a hardtop, you can find a balance and compromise, and be fairly happy - in a cab you have such vastly differing levels of noise, and start with a lot more noise to begin with than a hardtop, that it is impossible to find a single tune setting that accommodates all situations - you either get it right sitting still, or with the top down, or with the top up - never all 3 - top down is always a compromise anyway, as the lows and low mids get lost - the added complication of the low driver being in a spot where the sound never makes it up to your ear really makes a mess of things, leaving you with harsh and/or sizzly sound
so, i am finally giving up and biting the bullet - i'm cutting into my door panels - i'm going to install the same JL Audio C3650 speakers that i have in the SL550 - he 6.75" woofer will add a lot of low mid - i may build an enclosure inside the door - not sure yet - they sound great in the SL550, and i'm going to put them in a very similar location in the blue car, and drive them with the same deck, and similar power - this should finally solve the problem
i am ordering them today, and installing them immediately after they arrive
i'll be posting an ad for the kenwoods shortly
(This post was last modified: 08-01-2011, 02:19 PM by flash.)
