Threads: 14
I am going to need to pop out both headlights this friday in order to get good access to the tops of the fenders for paintless dent repair, courtesy of a mechanic leaning on each fender.
What is the fastest/easiest way to remove the headlights?
Thanks!
1994 Guards Red Coupe, 58k, 6-Speed
Threads: 81
bave -
Send a PM to Etnier, he did a writeup with pics on 968.net, I just can't find it right now.
Cheers,
-Mirror
Threads: 81
Er, I mean here.....not 968.net.
Thanks E!
Threads: 20
I just had paintless dent removal performed on the pressure dents that frequently occur on the front fenders from mechanics leaning on them. If you follow flash's directions and then remove just the headlight -- be careful of the plastic rings because mine cracked when I barely touched them -- then there will be complete access to remove these annoying pressure dents from the tops of the front fenders. $150 and the fenders look new again. He also took out a couple door dings from the same fenders. Amazing what can be done.
