bill - in autocross, unlike on the track, weight transfer is everything. you don't want the car to be as flat in the corner. you need the weight to move around. on the track, you are trying to keep the weight a lot more evenly distributed. on many autocross cars, i, like many, actually disconnected the front swaybar. it's all about getting the rear to plant and grunt out of the corner.
M030 shocks and struts are gas.
torsion bars are the same on M030 cars as on standard cars
lowering to a point where the geometrical roll center goes below ground creates too much camber change and reduces net contact patch area, which costs time in the corners. so does setting too much negative camber. a lot of guys make that mistake. you can go down about an inch on these cars without getting into trouble. much more than that and it starts costing.
that being said, what you have now is a pretty decent setup for street and non-competitive track. i am not a fan of the M030 valving, as the gas preload tends to make the car jittery, especially in the rear. it would be limited in autocross, and you would find yourself fighting the setup.
you would be amazed at how many people do it wrong. it's as if they are all following the same book or something. i don't think many of the guys out there actually understand the physics. even more think that because a guy is winning that it's the car. some guys can just plain drive, and they would win in a shopping cart. other guys couldn't win no matter what car they had. in autocross, it's not the car, it's the driver.
eez - i'm running modified and re-valved qa-1 double adjustable hydraulic shocks in the rear and koni double adjustable hydraulic struts up front. the shocks are about $250 each, plus mounts and bearings. all in you get close to $800 before adding springs. the struts are about $700 each, and again you then add springs.
www.968forums.com
