03-31-2012, 10:18 AM
Thanks all!
I found a receipt in the glove box from last year (october 2011) showing that the timing belt was changed and the water pump was rebuilt (on the same receipt was a note stating the radiator was in bad shape and was fixed temporarily). I'm going to re-do the timing belt, balance shaft belt and all the rollers, but am on the fence about doing the water pump.
A more thorough inspection has revealed a history of kludges. I have non-original relays creatively wired into the fuse-box. The cooling tank expansion cap is non-original and not correct and allows water (not coolant, they only had plain water in it *sigh*) to escape -- thus probably the cause of the overheating.
The wire from the coil to the distributor is bodged together -- electrician's tape and the wire coiled and stuck in the receptacles.
And I'm sure I'll find some more "creative" mechanical work as I get further into it... I suspect my post count here will start going up dramatically!
Oh.. and my favorite so far... there's a spot on the left flank where someone has scraped off a Herbalife sticker -- thus leaving Herbalife scratched in the paint. Herbalife vendors should not be allowed to own Porsches.
