Help cleaning cab rear window!
Need some advice - a "buddy" <img src="/forum/images/smilies/968/mad.gif" class="smilie" alt="" /> of mine used stickers to hang a temporary tag in my rear window and when he pulled the tag down the stickers stayed behind. Any ideas to get the glue residue off without damaging the plastic?? I tried rubbing alcohol but no go, afraid to go any stronger without advice.
Thanks!
Generally, I have heard Novus recomended for cleaning (removes the fogging if you work it to death). Not sure about adhesive...
I would try Goo Gone in a small inconspicuous area and see if it works...definately soft cloth, no abrasives...
Regards,
WD-40 will take sticker glue off
Novus has a Cleaner and Polish. You want the cleaner to clean the plastic and then put the polish on it after. My experience with these products has been with motorcycle windshields and they work wonderful.
Goo Gone works wonders to remove adhesive, but definetely be careful so that it doesn't discolor the window.
Good luck.
[quote name='94SilverCab' post='34212' date='Apr 16 2007, 06:17 AM']Generally, I have heard Novus recomended for cleaning (removes the fogging if you work it to death). Not sure about adhesive...
Regards,
Jay[/quote]
I was thinking the same thing regarding Goo Gone, just too chicken to give it a try as my window is nearly perfect right now.
WD40 might do the trick as well.
Thanks for the great suggestions! I'll let you know what works out.
I would go the Goo Gone route. I'm sure WD40 would work but would be concerned about it getting on other surrounding surfaces - so you obviously couldn't spray it and should get a clean towel each time you needed to moisten the affected area. WD40 is greasy and it stinks. Goo Gone is citrus based and contains nothing that should cloud or damage the plastic - in fact I've never had Goo Gone damage any painted or plastic surfaces where other chemicals have, especially nail polish remover and alcohol based solvents. Follow it up with some Novus or Meguires Plastx.
Decided to try WD-40, worked perfectly with no residue or damage. Thanks guys!
Last Post by Roboman
11-28-2023, 05:25 PM
Last Post by NCPorsches
01-08-2023, 03:54 PM
Last Post by jsheiry
11-12-2021, 10:23 AM
02-29-2020, 05:58 AM
Last Post by Dottney
09-06-2019, 10:48 AM
Last Post by dlearl476
02-22-2019, 02:04 AM
Last Post by BOB968
06-19-2016, 10:15 AM
