09-08-2011, 01:43 PM
SO a couple of days ago, I go out to my car and start it. Everything was normal except for a knocking sound when I went from Park into Reverse. The engine appears to still be stable on its mounts. The Tiptronic appears to have correct fluid level. The engine still performs normally. The Tiptronic still shifts seamlessly whether in Auto or manual mode. I have gone into the engine bay looking for anything lose and have found nothing. The AC appears to still be mounted and the belt seems to still be properly tensioned. I checked the distributer and alternator to see if they might be lose.
The car still drives normally. There is no loss of power. The steering is still ticht. The wheels all seem to still be soilidly attached and the tires still look like they are new.
The sound does not appear when the car is in Park or neutral.
The sound does appear briefly when the starter is engaged.
The sound does not seem to be related to engine speed.
The sound will appear when the car is in a forward gear and stopped or in reverse and stopped.
The sound itself sounds like a diesel engine knocking badly.
In addition the sound is similar to the sound that the engine tins on a VW beetle made when they were loose.
It is utterly driving me crazy at this point.
Does anyone have an idea as to a possible cause or a way to triage this?
Oh and to be a bit more clear, once the car begins moving and gets above 10 MPH the sound disappears.
